GTX Capacitor
I have a novak gtx and i had a crash and broke one of the "prongs" off in an un solderable place, so my question is do i have to use the novak one or can i go down to a place that sells them and use that? assuming it has the same rating.......on mine it says "4700uf, 10v, 105 degrees f".......But novak recomend a 5600uf
link: http://www.shopatron.com/product/par...er=S5675/135.0
or do i even need to run one?
and i need it by saturday so i cant wait for postage
I woul d locate another, without it, ripple currents that the cap helps to control could damage your esc. Admittedly, if the gtx is well designed and ripple is a minpr factor, you could run without. I don't know that much about a gtx so I don't have a feel for that. I'd play it safe and locate another cap as closely rated to the orig as possible.
Either of them should work fine. As far as the voltage and temp ratings go, you'll want to use the existing ratings as minimums. In other words, you can use a cap thats rated for 10,16,25,35, etc. volts if you want to. Just don't go under the 10v rating of the original cap. Same goes for the temp rating, just dont go under 105 if that's what your original is rated for. The higher the temp rating, the longer life expectancy, up to a point. Of course with a variance in voltage/temp ratings comes an increase in physical size.
A 4700uF cap is very common and can be found in most electronics supply shops. The 5600uF is not as common and that's probably why novak recommends them. That's good marketing. Pay close attention to the polarity when you're installing your new component, reversing it can easily damage the new cap.
good luck.
good luck.
