Quick Advanced lipo question >
Old 09-23-2008 | 01:12 PM
STRINGCHEESE's Avatar
Default Quick Advanced lipo question
If I take 2 x 1500mah 20c 3s packs and wire them in parallel, what do I get?
I know I still get 11.1V, but what happens to my mah and "C" rating?
STRINGCHEESE is offline
Old 09-23-2008 | 06:04 PM
A 3000mah 20C 3s pack.
Assuming you started with 3s1p packs, now you have a 3s2p.
You do get twice the current or twice the run time as one pack. But the same C rating if you call it a 3000mah pack.
Dave H is offline
Old 09-23-2008 | 06:25 PM
^^^^ Exactly. Lots do the same thing as a way to feed amp hungry setups. Your continuous amps wired in parallel doubled, becoming 20 * 3 = 60amps.
Duster_360 is offline
Old 09-24-2008 | 01:39 PM
So, if I'm using a 30 amp (40 amp burst) esc and wire two 3s packs in parrallel that are rated for 20c I should be ok?
