Like Tree2991Likes
1/12 forum
Old 09-14-2008 | 12:54 PM
  #29311
Scott are you racing tonight? If so check around someone must have a AE t-plate to size up.
Ophidian is offline
Old 09-14-2008 | 01:58 PM
  #29312
Hi,
quick question, just wondering what brushless motor you guys run in pro12 modified on a medium sized tarmac track.
I've got a 7.5 from my touring car which i'm going to put into my 12th, just wondering if it'll be enough.
Cheers
Matt
drivingpro is offline
Old 09-14-2008 | 02:35 PM
  #29313
trackdesigner71's Avatar
Anybody tried out the new Audi based 12th scale bodies? I think Parma makes them...
trackdesigner71 is offline
Old 09-14-2008 | 03:11 PM
  #29314
PizzaDude's Avatar
Black Art makes them.
CRC carries them.
PizzaDude is offline
Old 09-14-2008 | 03:56 PM
  #29315
JayBee's Avatar
I like the looks of the Audi R8C....
JayBee is offline
Old 09-14-2008 | 07:51 PM
  #29316
Originally Posted by InspGadgt
All 3 of those are good choices and you can't go wrong with them. I've used the LRP QC2 and the Tekin FX in 1/12th stock. If you plan to go to a Spektrum system in the future I'd stay away from the LRP. Their BECs tend to be a tad too weak for the Spectrum recievers and many people have had problems with that. Also with my QC2 the metal contacts on the PC board where the wires solder in eventually delaminated from the board. With the QC3 built the same way I imagine that would happen on that one too. The Novak I believe has the smallest foot print but also the largest capacitor so overall the GTX and FX end up taking up about the same amount of space. I really like my Tekin FX but you have to get used to adjusting push or anti-drag on the ESC and not on the radio. Many people will bump up the throttle trim to adjust this but the FX will not let you do that. Also if you plan to go to BL before going to mod brushed then save yourself a bit of cash and get the regular FX not the Pro...unless you are running hot mods you'll have no need of the Pro.
To be completely honest, I understand very little of that (I'm really not that electronic-savvy, but I would like to learn).
Sunshine86 is offline
Old 09-14-2008 | 08:10 PM
  #29317
Rob Burns's Avatar
Anyone know where I can get small spur gears for 12th . Right now the smallest I can find locally is 88. I know PRS make 76 and 80 tooth spurs but shipping to Canada is $20 for one spur.
Rob Burns is offline
Old 09-14-2008 | 08:56 PM
  #29318
It's like that to Hawaii too...and they don't answer e-mails. They sure make great gears but don't seem to want customers.
The Robinson machined gears get down pretty small too.
Stormer has PRS 76's in stock:
https://www.ssl-stormerhobbies.com/c...s&pn=PRS6476PL
And here's a 78T Robinson:
https://www.ssl-stormerhobbies.com/c...=ns&pn=RRP4178
InspGadgt is offline
Old 09-15-2008 | 08:23 AM
  #29319
Originally Posted by Ophidian
Since asphalt is low traction my guess would be Speed 8 HD as the HD stand for high downforce
Great! Thanks bud!
RC12 is offline
Old 09-15-2008 | 11:14 AM
  #29320
Rob Burns's Avatar
I ordered that exact Robinson Spur last week but with no pictures I didn't know if it would come with the holes for diff balls. Anyone know if it will or am I SOL?
Old 09-15-2008 | 02:15 PM
  #29321
junelopez's Avatar
Default Is there any way I can install BL motor onto a CRC T-Force
I have a CRC T- Force chassis and don't wish to buy another car, just curious to see if I can fit a BL motor into it or do I need to buy another rear POD.
BTW, does anyone here run the diggity design chassis, the one with the battery down the center?
I appreciate your advise in advance.
junelopez is offline
Old 09-15-2008 | 04:03 PM
  #29322
PutAwayWet's Avatar
Here's a couple pictures of my T-Fource with an LRP ESC and Novak 13.5 installed. You shouldn't have any issues.
Attached Thumbnails 1/12 forum-t-fource.jpg   1/12 forum-t-fource-pod.jpg
PutAwayWet is offline
Old 09-15-2008 | 04:20 PM
  #29323
junelopez's Avatar
How well does it preforms? I thought that the reason they CRC came out with the new chassis is because the old one did allow BL motors. I feel so stupit..
Thanks for the information..
do you run on asphalt and carpet?
Old 09-15-2008 | 04:34 PM
  #29324
PutAwayWet's Avatar
I run on asphalt and carpet.
CRC's new pod and hub are optimized for longer brushless motors and their attendant difference in weight distribution within the pod. They're for the Gen X, only. But brushless motors have been run for several years now in CRC and other 1/12th scale cars without any real problems.
That said, I'm hoping CRC will update the T-Fource soon, leaving the standard front end and simply tuning the pod/hub for brushless motors as they have the Gen X. Until then, though, I'm running it exactly as you see it.
Old 09-15-2008 | 05:05 PM
  #29325
Default Delrin rear bulkhead
Do the Speed Merchant delrin rear bulkheads fit the AE12L and CRC t-fource cars? Is it the same bolt pattern?
Tuner EM is offline
