Hard case lipo pack under $35.00 bucks!?!? >
Old 05-31-2008, 08:12 PM
  #241
mog ruith's Avatar
so its safe to charge at 3amps
btw can you explain this? i dont quite understand it
You have to remember that once a pack hits 8.4v(80% charge) the amp rate drops till the pack is 100% charged/.. its no like it takes the hit of amps right to the 100% charge point.. there is no risk of overcharge
mog ruith is offline
Old 05-31-2008, 11:29 PM
  #242
alana07's Avatar
Trader Rating: 53 (100%+)
bro, you can charge it at 1C rate, which is 3.2 amps using the hyperion 610 charger. this will give you good performance/lifespan. i charge my orion 3600 at 3.6amps using hyperion 0606i charger.
alana07 is offline
Old 06-01-2008, 05:02 AM
  #243
Trader Rating: 22 (100%+)
Default 1c
Yeah Racing recommend 1C is all you should charge these at. Manufactures recommend the charge rate for their own batteries.
People that charge batteries above the recommended rate are the reason lipo have had a bad name in the past. Sure, it works for a while but it shortens the batteries life and it is dangerous.
Anyone caught charging more than 1c at our club is asked to stop or leave.
Terry
Team Ash is offline
Old 06-01-2008, 05:49 AM
  #244
Joel Lagace's Avatar
If yeah only recomends that then go with that. but others such as orion and smc are recomending 1,2 and sometimes 3 C charging... With the disclaimer that the 1000cycle lifespan may be reduced....
the horror stories from lipo have been from using improper chargers or setting proper chargers wrong.
Over charging is dangerous(above 8.4volts)... Hi amp rates are not nessarily dangerous if the pack is designed for it.
Joel Lagace is offline
Old 06-01-2008, 06:39 AM
  #245
mog ruith's Avatar
all right thanks all
all this while i have been charging at only 1 amp just to be on the safe side
so now i think i will charge at 3.2 amps
Old 06-02-2008, 10:39 AM
  #246
espresso1967's Avatar
Trader Rating: 18 (100%+)
Anyone know if this will fit the new CRC Gen X 10?
espresso1967 is offline
Old 06-02-2008, 01:00 PM
  #247
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Orion Kokam can Max 2C to charge
RC MARKET is offline
Old 06-02-2008, 03:18 PM
  #248
KorruptedKarbon's Avatar
Trader Rating: 11 (100%+)
recieved my lipo fast. Everythign works good! This pack puts out more than enough juice for my vxl rustler, and for my mamba max 5700 in a TC3o v3.
Hope this helps anyone, i plan on buying another pack just so i can run a bit longer!!
KorruptedKarbon is offline
Old 06-04-2008, 04:27 PM
  #249
Dan/Ultraline's Avatar
Should fit just fine.
Not sure if you picked yours up from us, but glad you like um.
Dan/Ultraline is offline
Old 06-04-2008, 05:44 PM
  #250
RC MARKET's Avatar
Which charger had Hii Amps Discharger function ( CE GFX ) ?
need or have balance discharge ?
Old 06-04-2008, 05:55 PM
  #251
Just ordered 3 from www.ultralinehobbies.com for my 1/10 pan and will get a review soon as I get the car up and running.
Old 06-05-2008, 04:09 AM
  #252
Thank You espresso1967 for your support
Old 06-05-2008, 11:25 PM
  #253
RC MARKET's Avatar
Old 06-05-2008, 11:27 PM
  #254
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
30c? no wayyyy
Syber Serulean is offline
Old 06-06-2008, 07:38 AM
  #255
RC MARKET's Avatar
Originally Posted by Syber Serulean
30c? no wayyyy
30C or new type 20C ?
Attached Thumbnails Hard case lipo pack under .00 bucks!?!?-ori14007.jpg   Hard case lipo pack under .00 bucks!?!?-ori14007a.jpg
