Hobao Hyper .12
Old 04-15-2009 | 12:02 AM
  #31
Bundy_Bear's Avatar
Hi
I just pulled my Hyper 12 out of my G4JS and it had oil on some of the clutch parts that i thought was weird. It was on the clutch weight and the clutch pad itself. At first i thought it might have been the front bearing, but i couldn't see an evidence on the bearing or the flywheel. Any ideas????
Maybe i should give it another go and try and tune it better with the Nova carby.
BB
Bundy_Bear is offline
Old 05-23-2009 | 11:25 AM
  #32
tomdedoggz's Avatar
Dear all hobao hyper 12 expert,
I'm newbie and just brought a Hobao GPX4 RTR with the Hyper 12 engine. I have few question here.
1. When my engine run for few min I can see the smoke come out form the engine..... what the problem it that engine too hot ... how to I reduce the hot?
2. How I can do the car tire alignment ??
3. how to tune the car and what part need to upgrade on this model ???
Thank in advance ...
tomdedoggz is offline
Old 05-27-2009 | 08:29 AM
  #33
tomdedoggz's Avatar
Hello ..... can any expert in here help me on the problem above .....
Old 05-27-2009 | 08:40 AM
  #34
GREGORY!'s Avatar
first of all,how hot is going?
after that,if you read this thread you will see that the carb usually leak.just seal it.than that go with the stock settings in the carb and go for there.
GREGORY! is offline
Old 05-28-2009 | 08:46 AM
  #35
tomdedoggz's Avatar
How to seal the Carb or what type of Novarossi carb that can fit for hyper 12??
Old 06-06-2009 | 09:02 PM
  #36
tomdedoggz's Avatar
Fuel Line has air bubblz how to fix ?? Please HELP Urgent ..... my car cannot run .....
Old 06-07-2009 | 03:56 AM
  #37
Nitro-Racer*'s Avatar
hmm this engine has been a nightmare even to me.... acording to the thread maybe the bubbles in the fuel line are caused because the carb is leaking(had the same problem). use a nova carb. start reading this thread from the begining and your problem will be solved(partly or fully maybe*hate this engine*).
Nitro-Racer* is offline
Old 06-07-2009 | 09:02 AM
  #38
tomdedoggz's Avatar
What I know that the Nova carb will cost me 1/2 of the price for the Hyper 12 engine ..... will it worth to change it ??
Old 06-07-2009 | 09:39 AM
  #39
my opinion is no. just change the engine. it will (as to tuning and will be less problematic)be much easier to just chage.
Old 06-07-2009 | 10:04 AM
  #40
tomdedoggz's Avatar
Bro, I just brought the Hobao Hyper GPx4 RTR and not even run a round in the track and I'm newbies so it just too much for me to get an other engine .....
which is the carb that I need to change as per the photo the whole set of the carb or the gold color one as per the photo.
Attached Thumbnails Hobao Hyper .12-carb-12-.jpg   Hobao Hyper .12-hyper12-04.jpg
Old 06-07-2009 | 01:47 PM
  #41
the carb is seen in the photo on the left, the gold colour one is not a carb, but a cylinder!!
Old 06-07-2009 | 11:33 PM
  #42
tomdedoggz's Avatar
If change the cylinder will it help ?? can I know the Novarossi Carb Item No# ???
Old 06-08-2009 | 03:05 AM
  #43
no do not think that its the cylinder. if your engine still has compresion then a new cylinder is not needed. i believe that its the carbs false.
everyone says that a nova carb will work so my novarossi's carb number is:
#10608
hope this helps
Old 06-08-2009 | 06:18 AM
  #44
tomdedoggz's Avatar
thank for your help .... over in malaysia is very hard to find the nova carb ....
