Xray NT1
#2867
#2868
hi guys.. i noticed in this nt1 there is some air bubbles in the fuel line
i never had this issue with the rrr .. is it because the fuel tank is screwed down tight onto the top deck??
how do we overcome this??
thanks
thanks
#2869
#2870
Optional : Open the nipple, put a dab of glue on the threads, close it again until it stop turning ( don't use force ). This should ensure the tank is always pressurized, no air leak.
#2871
i had issues setting my clutch up, but a mate at the track finally
sorted it out for me, here are the clutch settings:
flyweights: Kyosho, drilled out to 4mm holes
clutch shoe: xray yellow
clutch bell: xray ventilated version
flywheel: xray lightweight version
spring: CRF square spring
thrust bearing: mugen
spring tension: .5mm from end of nut that holds flywheel in place
clutch gap shimming: .7mm (shim until bell does not touch shoe,
with both bearings installed and then add an extra .1mm shim)
endplay: .2mm
works awesome now!
these measurements weretaken using a digital clutch gap/endplay tool, (not verniers) so
measurements are very accurate
#2872
endplay: .2mm
works awesome now!
endplay: .2mm
works awesome now!
#2874
Kamikaze Toys also has that exact Cen Tech brand. A must have tool for the serious racer.
http://kamikazetoysandhobbies.com/pr...php?prod=TTCT1
#2875
true. i used one a mate lent to his mate, and it's the best specialty tool i've ever used. best peice of equipment o've come acros for a while. i'm definately getting one when i have the cash
this tool will allow you to assemble and disasemble your clutch after each race day and have it perfectly exact like before each time. by disasembling the clutch you prolong the life of the clutch spring and slow down the process of the spring going soft.
#2876
endplay: .2mm
works awesome now!
endplay: .2mm
works awesome now!
The spring tension specs does not match the photo you show. That clutch nut seems to be more like 1.2 - 1.5 down from the end. A caliper is also needed to measure this, but yes.... that tool is great!!!
#2877
Not sure if someone told this already, but those pins sticking higher than the shoes if not good. That may be why you can not set the clutch gap correctly and also why the clutch will never work correctly.
Regards and sorry if this was already pointed out.
DJ Apolaro
DJ Apolaro
#2878
That's because he's not using the original Xray flywheel. You will also notice that the clutch bell seems to be rubbing on the adjusting nut. I would suggest you either use the original Xray nut or the Kyosho which is 0.20 shorter than the Xray nut.
#2879
#2880
Hey Dennison,
I left you a message on your cell phone. Not sure if you have the same number or not, but is was about 1 week ago. It is the number you gave me when you got here to Florida. Call me today after work on my cell 305-586-6072, anytime after 4pm. Also the clutch will not work properly with those pins sticking out like that. They can not pass the shoes.
DJ Apolaro
DJ Apolaro
18Likes
