Tamiya mini cooper
#6171
Everything on the M-04 except the main chassis, rear shock tower, body posts, front bumper, pinion gear & tie rod ball-connectors can be carried over to the M-03... they use the same B+C parts trees, and essentially the same metal parts bags. The one exception would be the rear wheel spindles on the BMW Z3 Roadster kit... it uses longer spindles & thicker wheel hubs to increase the rear width, and those would push the front wheels out too far, if used on a M-03.
Also, the M-04L VW Beetle kit uses the lightweight reinforced uprights that are standard on the M-03M, but all other M-04 kits use the old style uprights. Regardless, the complete hub carrier assemblies(C-hubs, king pins + smaller bearings) are interchangeable onto the older kits, and vice versa.
#6172
[/QUOTE]
Regardless, the complete hub carrier assemblies(C-hubs, king pins + smaller bearings) are interchangeable onto the older kits, and vice versa.[/QUOTE]
Thanks MEPs.
I also notice the FF02 chassis looks an exact replica of the M-03.
Thanks MEPs.
#6173
#6176
I'm sure its been asked a hundred times but whats the internal gear ratio of the M03 (I assume its the same for all 3 versions)
I'm going to have a little brushless fun with mine this weekend
#6179
We have a couple of the exige controllers around the shop, but i need some wheel time with the Feiago controller so I was going to put that in with a 10.5 I have laying around the shop.
This is for no other reason other than its the only equipment I have laying around not already installed in something else.
I'm not a big fan of the Exige controller, at least not until they make some improvements on it. Even if it would only be used for Spec style mini cooper racing.
#6180
What are the part number I would need to convert a older m03 mini cooper to same specs/wheelbase/suspension as the m03m suzuki swift style.
Look like a chassis extension is needed and clearly the longer suzuki body.
Thanks for the help.
Cheers
Jamie
Cheers
Jamie
295Likes
