NOR*CAL RC track!
#78
are there quiet days when you can just go run some laps for a few bucks at norcal hobbies?
I'd like to run on a track for fun, without getting all hardcore about it
just wondering if you show up on like a tuesday at 2 or something if they let you out there
maybe like early on a sat or sun or something
#80
Artie'sLiver (good name), It is best if you call before you drive over to practice. Hard to tell how long the track is closed for drying out after a rain but they have it open most of the time.
#81
sounds fun!
I'll probably try it out at some off peak time
gotta get the B4 and soon to be finished brushless crt.5 out there!
#83
should be on this weekend!
#84
today
was just at nor cal hobbies today to pick up some arms. looks like a nice place. guy in the shop was pretty nice also. I dont think i will make this week ends race but i will be racing 2wd mod at the next race (i hope).... what are you guys runnin for tires??? what about shock oil (wt)?? and piston size i will be running an rb5 but any info would help just so i'm not in the dark. do you have a big 2WD class????
#85
They do have a big 2wd class and a big 4wd class. For tires most guys are running hole shots some bowties.
#87
Not really loose, infact for an outdoor track I would say it is pretty hard packed. Some times I run tapper pins but they don't always work, hole shots work better most of the time. They do sweep & slightly wet the track normally. I only run 4wd so I'm not real sure about 2wd
#89
4wd is open mod, 2wd is 13.5/19T mixed. Truck has separate classes for stock and mod.
