M11 doesn't save settings
Hello
I've got an used M11 but it has got a problem
I cleared the previous data and started to set trim epa to my car... I did all necessary changes and then shut off transmitter.. I turn it on and all changes made disappear.. the radio didn't save it. What is this?
The M11 doesn't have an internal battery set up. The M8 was the last radio to use that set up.
Do you have a wrap on the grip? If you have the button depressed on the grip from a wrap it won't save the settings when you turn it off. Remove that section of your wrap and you should be able to save the settings no problem.
hi guys, i need some info. i am having a 3-4 months old M11 that came with the rx431 receivers 75mhz freq( i got it new) . Recently it is behaving weird each time i turn it on, the servos throt and steer will glitchs/vibrates...and when i rev up my engine all hell's break loose
wonderin if any of u has overcome similar problems and what is causing it.
just for info i still got my 3 year old M8+311receiver and it's still working good.
wonderin if any of u has overcome similar problems and what is causing it. just for info i still got my 3 year old M8+311receiver and it's still working good.
Hi guys, would appreciate so much any info or analysis regarding an issue with my M11 Tx...i did something stupid which made me to decide to ask for advise or analysis from you electronics gurus. recently, i bought a used Sanwa RD8000 for my heli and the batteries are not good anymore, so i used the m11 batts and modified the terminals on the battery plugs and mounted it with parca at the back of the RD8000, the red wire being on the side and the black on the middle. when i had to use it on the M11, i forgot to move it back to the original position and just plugged it on the M11 socket right away. i turned it on but it did not power up and so i remember that i had to move back the red wire to the middle and the black to the side, afterwards, i plugged it again and i still it did not power up...did i burn something inside? might be a power IC? I hope you can advise me on this matter...I just
want to know the most probable cause/damage so i can explain it to the hobby shop that can do the repair for me...thanks in advance...
Slammer617
Singapore
Slammer617
Singapore
Plugging in the battery backwards can trip the diode in the handle. The radio would have to be taken apart and the diode replaced. If your hobby shop can fix it, great. If not, I'd recommend sending to Airtronics service. There could be more wrong with it than just that, but it's hard to say....
