Abnormal Problem ..... pls post here .......
Hi,
I created this tread for the abnormal problem, no matter on what ever topics (but make sure it's a problem which you think is abnormal.... pls) ...... and hopefully it can help all those newbie ..... like me !! & some other members out there.
And experts pls give your hand to HELP !!!!
Thanks in advance ......
And hope that this thread can be an active one
My 1st problem ....
My top/upper/last pc of my aerial of my 3PK controller come loose/out of the main areial body......
Kindly look at the attach pic.
Anybody face this problem b4 ??
How to solve or repair ??
soli soli
How to attach a pic ??
I have use the attach file at the bottom below the option of this page, but it doesn't work....
Help needed pls ....
[IMG]C:\Documents and Settings\cslo\My Documents\CS-Fujitsu\aerial.jpg[/IMG]
u have to use the "attach File" thing at the bottom of the reply screen
Originally posted by Manticore
you have an abnormal problem with putting picture here !
Try again ....
i hate when that happends
2nd problem ....
I already got my pic uploaded
Now my 2nd abnormal problem ...
I have got a K-Factory front CVD recently for my V1RR and after running for abt. 10 tanks of fuel, suprisingly the pin at the end of the dogbone come out .....
HELP .....
and here is the pic ..... (hope it work this time.....)
HELP .....
Try again ....
Try again ....
and how you solve it ??
Re: 2nd problem ....
HELP .....
HELP .....
there is nothing much you can do to repair it. you may either stick with the broken antenna or replace it with a new one.
but still hoping to gEt some information .......
HOPEFULLY
Re: Re: 2nd problem ....
I think k factory has replacement part for the bone only. dont try to fix it, the pin will come off again sooner or later.
what will happen again if i replace the bone part ? will this happen again ??
Or is the K-Factory CVD worth buying ??
