Kyosho V-ONE RRR Evo >
Old 09-09-2007, 10:02 PM
  #2191
kewdawg's Avatar
Originally Posted by GMartinez
ON the 2d clutch you will feel a faster engagement or quicker spooling
settings on gap will be the same as the 3d
spring tension should be set from .30-.50
endplay very little then you would normally set the 3d
George,
the "I-95 Showdown" is calling your name! Give me a holla when you get a moment.
kewdawg is offline
Old 09-10-2007, 10:10 PM
  #2192
H4gI's Avatar
Nice quality..... That gear was under 20minutes of running....
There are some parts wich are not that good....
Attached Thumbnails Kyosho V-ONE RRR Evo-ritzel1.jpg   Kyosho V-ONE RRR Evo-ritzel2.jpg
H4gI is offline
Old 09-10-2007, 11:17 PM
  #2193
Trader Rating: 28 (100%+)
Have you contacted Kyosho regarding this?
Scott Fisher is offline
Old 09-11-2007, 01:55 AM
  #2194
bradman's Avatar
Does anyone know if the kyosh gp-10 spider 4wd is a good enough car to race with?
bradman is offline
Old 09-11-2007, 02:23 AM
  #2195
H4gI's Avatar
haha In switzerland we don`t have that nice support. Forgett it, the official of Kyosho was laughting and that`s all....
Shit happens...
H4gI is offline
Old 09-11-2007, 02:49 AM
  #2196
Sp Racer's Avatar
Trader Rating: 12 (100%+)
If it was September 1999 it would be a great car!..
For club racing or racing up and down the street it would be ok - you'll find parts extremely hard to get.
Sp Racer is offline
Old 09-11-2007, 02:55 AM
  #2197
EiKuD's Avatar
hie all....i got a prob with front tire rubbing againts bottom shock ball joint...i have read previous thread tt some say you should put an O-ring behind the dog bones, but i read thru the manuals it didn't not show that an O-ring is needed, do you guys add an O-ring behind or just unscrew the 9mm pillow ball more ??
EiKuD is offline
Old 09-11-2007, 06:28 AM
  #2198
Trace's Avatar
For wheels rubbing the shock balls.
I'm looking at two cars right now with the same thing. Parts on order.
KYOSHO P/N UM112
1. If your txmitter can do it, set the end travel limits or the steering
proportion so the wheels don't touch at full turn. (Move the suspension
full up and down when checking.)
Check the offset on the wheels. .... an unnamed buddy of mine put 30's
on the front a did a good number on his!
Trace
Trace is offline
Old 09-11-2007, 09:21 AM
  #2199
ziggy12345's Avatar
Its a perfect car to race against other Kyosho GP-10 spiders
ziggy12345 is offline
Old 09-11-2007, 12:58 PM
  #2200
Anyone had ever tried the UFO clutch type from k-factory?
Is it good as they say? Better than 2d or 3d kyosho clutch?
Ramiel is offline
Old 09-11-2007, 01:13 PM
  #2201
rmdhawaii's Avatar
The front rim rubs up against the shock ball joint because of the steering throw adjustment. If you adjust your throw so that it goes as far left/right as possible without touching, it should be fine. Rotate your tires to make sure it doesn't touch, as the rim may not be perfect. Also check it if you switch tire brands on the same day. From my experience, it always rubs - unless you leave a fairly large gap between the rim and the ball joint. IMO, once you have a nice groove in your ball joint, it's not really an issue.
rmdhawaii is offline
Old 09-11-2007, 03:17 PM
  #2202
GMartinez's Avatar
Trader Rating: 91 (100%+)
Originally Posted by kewdawg
George,
Quinn can't make it with the florida state series beginning in a couple of weeks I will be going to a pre warm up where race 1 is ging to be held
I am dying to go to 301 but it looks like I will have to wait till next year
hit me up on the cell
GMartinez is offline
Old 09-11-2007, 03:23 PM
  #2203
GMartinez's Avatar
Don't like it very much as all of the K-Factory springs are way to soft not to crazy about purchasing an item & you would have to use different manaufactures springs to get it as close to performing up to kyosho's standard Im using the Kyosho 2d clutch more than the 3d
Old 09-12-2007, 12:05 PM
  #2204
Got it! thanks!
Ramiel is offline
Old 09-12-2007, 09:24 PM
  #2205
EiKuD's Avatar
KYOSHO P/N UM112
Trace
30's in the front ?????
EiKuD is offline
