Kyosho V-ONE RRR Evo
#2176
Can anyone give me some good info on how they feel the 2d clutch works for them. I installed one in my car this last week and have been having trouble getting it set where I like the feel.
I have never had a problem setting the 3 shoe clutch so that is why I am a little lost right now. That and according to the instructions the setting they recomend are not even close to what I run on my three shoe.
What are some differences in the 2 clutch setups and why run the one over the other?
Or should I just add two more shoes and set it up so it is the same as a mugen clutch?
#2177
Last race it got some problems with my 2 speed. Every time when we adjusted it to shift later it shifted earlier. it didn't matter how far the screws where turned in. so we put some new shoes in the 2 speed but this didn't help much. So could it be that the springs are worn out, or is there something else wrong?
#2178
In my car I felt it with more bottom end power. and important it is very consistent.. holds the setting during a long time
#2179
G4 Lightweight Vent Brake Disc
Item No : K1443
http://www.kfactoryracing.com/produc...1443&pageNum=1
with k-fatory pads too
Awesome braking power with no fadding.
#2180
Location: Cebu City, Philippines and Ocala, Florida, USA
I got 89 mph with the RRR today. Here is a vid of an 87mph run just after
http://youtube.com/watch?v=UyMpLFYd0JY
It was uphill against the wind and with 20/56 gearing (The internal ratio is modified). I think I can get 100 mph next time
Cheers
Cheers
#2181
#2182
Hey Guys,
any talks of a new car coming out? or is this it for 2007??
thanks,
thanks,
#2185
I hope the 1:10th car is a completely new design and name its time for somthing fresh
#2187
settings on gap will be the same as the 3d
spring tension should be set from .30-.50
endplay very little then you would normally set the 3d
#2190
Well I want to say thanks for the guys that gave me suggestions on how to set a 2d clutch.
I finally got it set where I like it. I have it set with .4 end play the clutch nut set .4 and I put 2 .1 shims between the inside bearing and the clutch nut. This setup seemed to make the car really launch out of the corners. It felt really consistant through the entire run.
One question I have is I put a spool up front (which I like the feel) would this make the car launch out of the corner better. Or is it just the clutch making the car feel this way?
Does anybody have any setup tips on changing from a frontway to the spool?
