Kyosho Touring Car
#1501
Reedy setup
Guys here's my setup I ran at reedy race. My qualifying times were 21-5:01 and 21-5:02 which put me in the middle of the D main... Last year that time would of put you in the A main. I was running the kyosho stallion not the shine.. There was 3 guys who ran the shine... My car felt really good just could not get any power out of my motor... Anyways here it is
Front of car
CC in #2 spacer underneath block
CC in #3 spacer underneath block
2 hole pistons, 35 wt oil, middle shock position, Hpi gold springs
5mm droop on yokomo gauge
blk sway bar, 2.5mm shim on top camberlink
spool, camber 1, toe 0
Arm shims all to the front
Diff position A
1 mm wheel spacer
Rear of car
AA #3 spacer underneath block
EE out #3 spacer underneath block
2 hole piston, 25wt oil, middle shock position, Hpi silver springs
3mm droop
silver sway bar, 1 mm shim on top camberlink
camber 1 degree, toe is 2.5
Arm shims all the way to rear of blocks
Diff position A
I am a B team driver.....
Front of car
Diff position A
1 mm wheel spacer
Rear of car
3mm droop
Diff position A
#1502
Here is my setup from Reedy for the Shin Edition.
The setup was originally developed for the Stallion - Steve Wang continued to run this after I converted my car over - the setup carried over really well.
#1503
Originally Posted by ODEN
Who are the Kyosho America team drivers that use this thread?
That can answer setup questions for the Stallion.
I know we all have our different opinions on what is a good setup for our track that we race on,(what ever country thats in) but in this thread
questions are asked about handling of the stallion and are vaguely answered
like, try 45wt and blue spring that should help! (Maybe).
I have a Stallion it's very good (Love Kyosho), I've gone faster with it than any other car I've have had so far, getting a Shin Version won't help me.
They look great, but I don't need it, my driving consistency is 0.13 of a second 3 out of 5 runs I'm just looking to find small inprovements in the car
at the moment.
So Who are the team drivers that use the Stallion regularly that I can ask
when I'm on RCtech?
(please don't miss understand this request)
at the moment.
when I'm on RCtech?
The electric onroad program is just starting to ramp up. Under the guidance of Gil Losi Jr and Joel Johnson, with Josh Cyrul leading the charge you can expect good things to come about.
Hopefully we can help you and others out with what you are looking for.
#1504
Thanks Guys, that helps me to ask the right people when I need to
ask.....there is a lot of good people on here(which is great) but some
seem to think if they get the new bit or car that will fix the problem.
Kyosho has got some very good people on board world wide, and I was
very pleased when Joel Johnson became vice at Kyosho America and now Gil losi jr It just looks as though most of the driving part (EP wise) is left
up to Adashi, (who is fantastic by the way) But a bit of a tall order for seemingly just one.
George I don't know if you are related to Adrian Martinez, but what he did on how
to build an MI3 was fantastic and it really would be a great world if all companies did the same!(Kyosho next!)
Thanks for listening, I'm just a Kyosho boy from way back and thanks for the
help.
help.
#1505
Regarding Adrian no relations to my knowledge although my father was a player who knows
help.
help.
& got hacked really bad in the main batterys started to smoke so I pulled it after 7 laps my friend took the A. I was able to pull exact laps times as 1st place fastest lap 14.6 & the car felt really good confident enough to put in some faster laps but I guess I have to wait till race 2
#1506
Steve Wang
p.s. MDawson...so we going Nats?
#1508
Can you post up a bigger picture? Its too small to see some of the writing.
Thanks.
#1509
#1510
TF-5 shaft or belt
Wanted to know what car will be much better on a small tech. track, we use sugar water as a track additive. The motors that are only allowed to run is the tamiya blackcan sport tuned, rubber tires, and with a final drive ratio of 6.58.1 Also how durable are the new cars are, I have the touring nitro cars and they are very durable
#1511
Just curious, is this a special series event that requires blackcan motors?
#1512
Its not a special event just a local race here in Hawaii on sundays trying to keep the cost down and everyone on a level playing field speed wise. You can run any type of chasis in the touring class except as noted in my earlier post body style as long as its not a wedge type of body.
#1513
Mark Dawson or Mike Molina
Would either of you guys have an hour spare on Thursday evening to shoot over to Socal? There is a new guy Kenny who just got himself a TF5 and it has setup issues that you guys might be able to solve for him. He wants to run Socal Friday and BCR saturday so I figured one of you guys could help him out a little..........keep the new blood coming no?
#1514
#1515
Thanks Mark I will let him know Thursday
