Liner breakage on .21 engines ?
Hello,
I would like your opinion on this problem:
last weekend I broke two liners in half of two different motors. It looks like this
The engines where a Novarossi 35 Plus 21 and a JP FX 21 R03.
Both engines were in excellent condition.
I never had this happen to me in three years time.
The only fundamental thing I changed was that i ran the Sirio 2013 exhaust on both engines. Normally I run the Novarossi 2052 exhaust all the time.
Do you think the exhaust can cause such breakage ? Because two engines in a couple hours time is a bit far from bad luck.
Or do you know of other reasons why a liner would break in half ?
Best regards
Best regards
Never knew what happens with those ultra-high port engines and the yours (AFAIK, your two engines are 7+2 ports).
I can only aventurate an answer for you, maybe is true, maybe not, but... logical, tells that's possible. Let's see:
On those engines with such high number of ports, the metal thickness between ports is very reduced and suffers a lot the high temperatures, crankcase robs heat from the sleeve, but with such low quantity of metal to transfer the heat, it weakens and after some time it fails by the weakest part, the metal between ports (this is exactly where your sleeves failed).
Many years ago, the port craze finished (8,9,11 and up to 13 ports were available) and until few months, haven't seen a 9 port another time, but seems that old metallurgy problems still predate them.
Could be quicker, could be powerful, but they still suffer the reliability problems like the high competition engines, who have a short but very intense life. I feel so bad for you.
My advice, change them for some 7 port sleeves, maybe will not be so quick, but... will live longer.
Thanks for the advice Corse-R on changing from 9 ports to 7 ports but the problem is that the Novarossi was indeed a 9 port engine but the JP was a 7 port engine.
In defense of your argument though, the JP was a highly tuned 7 port engine so in fact it could be that it was just as weak as the stock 9 port engine.
The thing that keeps me puzzling though is that the engines failed so close together of each other while they are so different. The JP had done only half the mileage of the Novarossi and even the Novarossi hadn't done that much racing. Both engines were only used in national championships and never for simple training. I am afraid it will remain a mystery why they died.
Now I am going to buy the 359 race .21 Plus 2 edition pack. It contains the new 359 race engine and a training engine which also isn't that bad if i hear the rumours.
Hope engine failure leaves me alone in the coming months because if it happens again then the racing season 2007 is over for me. Those things just cost to much money for a non sponsored driver.
One last question though, if you would buy another racing engine today in .21 classe what would you buy (for competing in national championships) ?
The Ninjas are going very good, are comparatively cheap (if we can use that word on On-Road engines) and they're quick and durable (I have a pair and I'm very satisfied with them). if you have guts and finger to control it, the Mario tuned version will be a serious beast looking what it did with the Off-Road.
On-Road racing is a matter of horsepower, but other things are key for putting that power on the ground (perfect clutch adjustment, clutch and clutch... said you... Clutch?
).Grab somewhat with a true 7 port sleeve.
Hello,
Best regards
Best regards
on a dutch forum where "spillertwo" also raised this question, a remark came about somebody trying a Ninja pipe on his R&B, and engine temp. went up to 150C (300F)
As the Sirio 2013 really works well on the Sirio AAC based engines, like R&B XenonR, this pipe might well be not really suitable for ABC type of engines.......
