CEN Matrix TR
#241
Originally Posted by Machine's R/C H
The RTR TR Arena imo is the best RTR you can get. But to be race worthy, he will need to get the CNC susp holders. Everything else is good or the same as on the FRE.
#242
#244
Yes
#245
if he later wanted to switch the engine a trinity drake 28 or a werks 28 would drop right in right?
#246
Yes. Any engine will fit.
#247
good frikin info
i am new to this forum and i must say that this by far the most informative, in depth discussion i have read about the CEN TR, i am going to be placing my order for one tonite and am glad to see and read all of the info you all have posted. thanks and look forward to reading more...
#248
i doubt if he changes the diffs soon but to start with does the rtr have good fluid in them or should he get some of that kyosho red or black diff fluid?
#251
The diffs come with grease which will work fine to start with. Then get my cross pin converstion kit.
I am using 17mm hubs to narrow the truck up some. The proto truck had shorter arms but I used extended 23mm hubs. Also, the 17mm hubs are half the weight of the 23mm's. And Pro-line finally released offset 17mm wheels and I like them.
http://h1072672.hobbyshopnow.com/pro...prod=PRO269202
#252
Also, when we were testing the tuck, 17mm wheels would easily strip out. But now I am using the KMW Racing flandge nuts which stop that and really hold the wheel well.
#253
http://www.headrushhobbies.com/estor...?pid=856&catn=
#254
to anyone wishing to purchase an arena tr, i wish you would give gene a shot. he provides great info and support, i think that is more valuable than the little amount of money you MAY save.
jlo
jlo
