Novarossi engines thread
#1892
Originally Posted by joemugen
I am about to break in a murnan +12 sct. I use 30% nitro, do I need to shim this engine out. If so, how much?
AFM
#1893
#1896
Originally Posted by mrgsr
hey guys
wats a good glow plug for a novarossi race .21 running 25%
the engine came with a RB 6 plug so im after something same as that
thanks
John
thanks
John
for onroad go with no.7
#1900
Originally Posted by ziggy12345
Quick question
For very cold weather...... 6 deg C
Increase head clearance or lower?
Hotter plug or colder??
Cheers
Cheers
and 5 for .12 onroad or .21offroad........
regarding the head clearance, I wouldn't change, anyway theoretically you should increase head clearance due to the higher content of oxygen in the air (lower the temp = higher the density of the air, which means you have a bigger volume of oxygen for a given volume of air compared to higher temps)...
you just need to run the engine rich, and this is why you need a hotter plug, to achieve a complete combustion...........
#1902
hey guys i got a novarossi based max power .12 sl3 engine, it a awesome engine just the prob is it needs a change of conrod and i cant seem to undo the head, the head bolts are for a flathead screwdriver which is very unusal, has any1 encountered this problem and what did u use other than a screw driver to undo it got me stuffed cheers kosta
#1903
all nova based engines uses this philips screw. we all normally changed it to 2.5 socket head screw, as i have a very very bad encounter with this nova screw, as the head of the screw snap off, but luckily, it still show a tiny bit where i can use my fingernails to turn it out, phew, else, need to get a new crankcase.
#1904
#1905
Once you got them out, you can change them for hex head screws from Picco /Mega/LRP.
195Likes
