Barracuda from Alex racing
#1141
Originally posted by TC3
how can the rear toe in be adjusted on the r2?
and the front caster (not kick up)?
As far as caster..?? the only way it can be done is by shimming the A-arm balls...ALex also sells a shim set that comes in .5mm/.75mm/1mm.
-Dave
#1145
DROOL!!!
Just a couple weeks away now it looks
Better start thinking of a nice new shell for it
and what I'm gunna say to the guys I race when I give them the shaft
could have nice new cells sorted by then too
#1146
6,8 balls and A-arms tips
Any tip installing the optional 6,8 balls on the new (grafite) A-arms?? I thing that the new a-ars are stronger than the standard ones.
#1147
Re: 6,8 balls and A-arms tips
2 words that will be come you best friend
Heat Gun or Hair Dryer
makes it a sinch' putting them in....or you can do i the old' fashon way...... Kung Fu Grip with a set of plyer's
-Dave
#1148
Thank you JDM
. I will try tomorrow.
Also do you think if its possible to install the sway bars from the HPI pro 3 (the rear one)?.
#1149
Hi Dave,
Can you provide some build tips for the car for us newbies who will soon have R2's ?
I know about the sanding of the gears but are there any other building advice you might know of?
Are there any issues (minor or major) we should know about?
Any hop-up recommendations that will improve performance (although there probably won't be many) ?
#1151
Hi Guys,
We'll also be bringing in the Purple color as well. So the two colors available right now are the Blue and Purple. Estimated date of arrival: March 14th!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Steve Wang
Speed Tech R/C
www.speedtechrc.com
#1152
Dave,
Is there a way you can make a carpet setup for the R2? I am interested in the car, but I don't have the kind of skill to set up a car right now. I just copy someone's setup and concentrate on driving. Thanks.
BTW. I just got an ITR powered EH/EG. It's quite insane.
-Leon
-Leon
#1153
Thank you JDM
Thank you JDM
Look in this pic...
#1154
How does the Cuda R2 deal with the grim that we get from racing on some less then perfect surfaces...tires dust and just the track itself can get all over the insides of our sedans...I know of the enclosed box that helps...but is the car able to handle a less than perfect racing surface for very long?
Great info on the 14th! Man better get my tools all layed out in wait to build a new kit!
Jeff
Jeff
#1155
Originally posted by Leon
Dave,
-Leon
Dave,
-Leon
BTW congrats' on the Civic!! ... Feels nice to have a car that weights 2150 and has about 195hp..
Just think of the car that I have with the amount of power I put to the ground!!
-Dave
