motor problems...
motor problems...
i have fatom 21 bump motor... the problem i have been haveing is when it has the body on it it bogs ... i have the hole windsheld cut out.... and when the body off from it it stales when it has about 1/2 a inch of fuel in it... dose this mean i have to rich it up? and if so what end the low or the hight end...? i need so motor help please help me out...
any 1 else have any info for me?
i thank it needs seals ... it has oil coming out of the shaft... and it cant be tuned... and it revs .. so how much are the seals .. and were can i get them? and any1 have a link ... thanks so much for taking the time to help me...
how do i know if the motor has low compression .. sence its a bump start motor.... ???
turn the fly
I'm pretty sure you will not find just the seals for your bearings. You will have to buy the whole bearing.
well i just cheched my motor... i can turn it over... but i have a new warhead i can turn that over also.... also can any of you send me a link of the seal and piston and sleeve?
also i dont know if this means anything but when i put after motor oil in it ... it has more compession...
