Like Tree2991Likes
1/12 forum
Old 07-23-2006 | 07:02 PM
  #19486
protc3's Avatar
just messin bro.cant wait for the weekend.
protc3 is offline
Old 07-23-2006 | 07:14 PM
  #19487
mike ivy's Avatar
Hey Protc3, Question for ya your BMI 1/12th scale car pictured above when it becomes availible all the the Aluminum parts on the kit do can they come anodized in Blue? Looks like a awsome kit
mike ivy is offline
Old 07-23-2006 | 07:16 PM
  #19488
speedxl's Avatar
Originally Posted by Marcos.J
yes is a P-Dub bumper,I have faith ,I just dont want to mess up this fine piece of work
Dude! why are you running a bumper? Take that thing off!
speedxl is offline
Old 07-23-2006 | 07:21 PM
  #19489
protc3's Avatar
i am looking into colors at this time.blue is a touchy color,its tough to match the other blues out there and its a like it or hate it color.i will figure something out in the next week or so.thanks for the props
protc3 is offline
Old 07-23-2006 | 08:25 PM
  #19490
Marcos.J's Avatar
Super Moderator
I will Hector as soon as I get it set up dont want to break anything
see you at B & B for the next state race
Marcos.J is offline
Old 07-23-2006 | 08:33 PM
  #19491
Marcos.J's Avatar
Super Moderator
I cant wait either, I just hope that the rain will stay away!!
Marcos.J is offline
  #19492
danjoy25's Avatar
Let us know how you go with running a Spektrum without an external battery pack
danjoy25 is offline
Old 07-23-2006 | 08:37 PM
  #19493
Marcos.J's Avatar
Super Moderator
its been running great ,I ran it just like that on my HARA 1/12th scale with no problems at all! Jason also runs is with out a receiver pack with no problems either.
Marcos.J is offline
Old 07-23-2006 | 08:38 PM
  #19494
Marcos.J's Avatar
Super Moderator
why put color in it? It looks great the way it is already
Marcos.J is offline
Old 07-23-2006 | 09:42 PM
  #19495
Yeti35's Avatar
How about some red CF? I have seen it done in a real car, specificly in someones '05 Mustang GT that was at a show I attended. I would be up for a red CF for my JRXS or my Carpet Knife.
Yeti35 is offline
Old 07-23-2006 | 11:02 PM
  #19496
Marcos.J's Avatar
Super Moderator
i think that a green color is faster than red
Marcos.J is offline
Old 07-24-2006 | 12:01 AM
  #19497
psychosilence's Avatar
Umm, I got a question!
How do I go about setting the tweak screws on the t-bar in a L4? I mean must I set them that the swivel is equel both sides or should they both be against the chassis but so that when the car is lifted at the rear centre point both wheels leave the ground at the same time??
PsYcHo
psychosilence is offline
Old 07-24-2006 | 12:13 AM
  #19498
DORIFT's Avatar
Dear all 12th lovers...
I got a problem. During my last race, my car behaved badly.
Here is the situation: During practice runs earlier in the day, the car was nice and sharp, no problems at all.
When the first round of qualifying began, the car started to have some minor twitches, and these twitches cossted me not being able to compete any further. The twitches i got is from both steering and power. The signal is not continuous, its like intermit signals...on/off/on/off (this is being exagerated a bit, but i think you get the picture) The problem was worse when the car is on front straightway with full throttle, the car would just steer to one side. The sigal from TX was alittle delayed as well, seems that when you press throttle and turn steering, the sigal is being delayed before the car actually has a response.
So when I stopped the car, i had a closer look, everything was fine, but when i had a look at my ESC power light, you can see the light is not staying on all the time... its like on/dim/on/dim....
What could my problem be? a stuffed Receiver? or just time for a specktrum upgrade?
The gear I am using is, KO 302 Receiver, KO VFS1 ESC, Futaba Servo. It is indoor carpet track by the way.
Thanks for any help.!!
DORIFT is offline
Old 07-24-2006 | 05:30 AM
  #19499
CarlosG.'s Avatar
Are you using the Helios? If so check to see if the tx module is did not force one of the junction fingers down, and check to see if it does it with another crystal set.You might want to check that you are not running on the same frequency as somebody else. also make sure your tx batteries are fresh and fully charged. If you are using alkalines( Energizers, Duracells....) always have a fresh set on hand, or buy a set of nimh batteries this way the expense of buying batteries is cut down. One more thing double layer the mounting tape for the receiver to the chassis. These are a few things that you might want to check out. I am sure there are others that some other people might have for you to check.
CarlosG. is offline
Old 07-24-2006 | 06:12 AM
  #19500
purpurite's Avatar
If the car worked perfectly fine before, I would say that it is probably NOT a Spektrum or receiver reception problem. It sounds to me like a loose or broken radio/ESC wire somewhere or even a battery that may be shorted on the chassis. That sounds like a ground/connection issue—especially if it just materialized.
            There are a few more things to check, but these are the most obvious and likely.
            purpurite is offline
