TC3 Forum
I drilled my own holes on my old TC3 arms & used 12th scale 4-40 setsrews from the dampner tube for droop screws. I ran these 2 years before they came out with them on the cars. I never broke an arm because of the holes in them. With the size of foam tires changing all the time you have to use droop screws because of the amount of times you need to adjust them. R.W.
Originally Posted by Rick Worth
I drilled my own holes on my old TC3 arms & used 12th scale 4-40 setscrews from the dampener tube for droop screws. I ran these 2 years before they came out with them on the cars. I never broke an arm because of the holes in them. With the size of foam tires changing all the time you have to use droop screws because of the amount of times you need to adjust them. R.W.
necessarily true, just keep a standard shock limiter that can be used at all time and then set droop with the shock ends, when the tire gets to small for the shock end to be adjusted right, replace with a smaller spacer, they don't need to be on the inside, the out side is much easier and works just about the same.
no matter what car you drive, drive it with other drivtrain layouts(4wd,rwd,fwd)
with that you will experience other lines and line factors that a different type of car can take...
AND with that you can improve you techniqe and speeds
Thrust me on this on
id rather not thrust u personally
Spool compaired to std diff with Sorex 24R rubber on carpet what difference would the spool make? i use a home made 1 on me drift but i never used it on a track. CHEERS!!!!!!!!!
what i am trying to say is like take out the cvds on the rear and then front and then put it both on again
like
4 wheel drive (4wd)
and then front wheel drive (fwd)
and then rear wheel drive (rwd)
and then back to 4wheel drive
now do you understand
like
4 wheel drive (4wd)
65Likes
