STS .28 pull-start engine
#166
Hi There
I have recently purchased a .28 STS engine. which I have put into my Rex-X. I have been running this for a couple of months now. But today I noticed that the LSN had come out completely.
If someone can tell me what the factory settings are for both the HSN and the LSN I would be greatful. I cannot seem to find this information anywhere.
Thank you all
Thank you all
#167
Hi, I´m a new STS .28 engine owner from Spain. My english is not very good, but i want to try.
I´ve got a XTM Mammoth with a XTM .24,7 engine and i want to ask you some questions.
I don´t know : How many Hp has this engine ? what about the RPM ?
I have recently purchased the .28 STS engine and i want to break it as soon as i can. what % nitro gas for break in ?Can i use my XTM mammoth pipe for the engine?. What pipes do you use on the STS28 ?
there are too much questions but i hope you help me.
Thanks you for all.
Thanks you for all.
#168
Originally Posted by T2UK
Hi There
Thank you all
Thank you all
LSN--3t
#169
Thanks you for all.
Thanks you for all.
#170
Hi Dino
Thanks for the needle setting. I also forgot to ask you what is the temp I should be aiming for. I know that this is dependant on weather conditions. Right now I am running at 200 - 220 F. I am using 25% Tornado.
Sorry to be a pain, but I'm not familiar with Head shims, what would be your recomendations? I'm not yet taken my cooling head off so I am unsure what is already there.
Thanks again
T2UK
Thanks again
T2UK
#171
Hi Dino
Thanks again
T2UK
Thanks again
T2UK
When the air temp. is 5~15C (41~59F) Keep the engine temp around 80C(176F)
When the air temp. is 15~25C(59~77F) Keep the engine temp around 100C(212F)
When the air temp. is 25~35C (77~95F) Keep the engine temp around 120C(248F)
When the air temp. is more than 35C (95F) Keep the engine temp around 140C(284F)
If your engine works just fine and you feel the power is enough,you don't need to worry about the shim's setting. All STS engine shimmed for 30% nitro,if you are running 20% or 15%,you may need to remove some shims for getting the most power.
#173
Thanks Dino for all your advise. I've not had a chance run it yet but I'll be running my buggy tomorrow. Can't wait to WOT cos I know what this .28 can do
p.s why is there no technical spec on www.sts.com.tw regarding .28?
#174
Originally Posted by dino.tw
Sorry,we have problem on the rotostart backplate. Another company FLYING-POINT Co, Ltd. claims that they have the patent right of the rotostart backplate. So we can't sell it. That is why the rotostart backplate be delayed. We are talking with the FLYING-POINT Co, Ltd. We need to buy the backplate from them then install on our engines.
It's a real shame that this technicality should prevent you from being able to design and sell your own roto compatible back plate for what is afterall your engine!! I find it hard to understand why a company has any right to patent what amounts to just a couple of gears mounted to the back of a nitro engine. Surely similar mechanisms must exist for many other applications!!
What you need is a good lawyer!
Good luck.
#175
From: San Mateo, CA (20 miles south of San Fransisco)
Hi, you guys all seem pretty knowlegable about nitro, and I'm just getting into it, I just have a question about glow plugs. How many starts will a glow plug last for, or will they just last for one? i know that the glow starter will charge up enough to start the car a few times, but how many starts will the actual glow plugs last for? Reply to this or private message me with the answer please! Thanks!
#176
Hi
Glow plugs should last quite a while, but you need to make sure the plugs you use are correct for both your engine and suited to the particular fuel you use.
Things like the ambient temperature play their part also - on both the tuning and what plug works best.
I'm in the UK, use 25 percent nitro fuel and find that RB No 6 plugs work well. Less nitro = hotter plug. More nitro = colder plug.
I inspect my plug after every run. If it starts to look dull, I change it BEFORE it breaks. How long they last depends on how hard/frequently you use your engine and also how lean you go with the mixtures. But you should find that they last between at least 2 weeks (2 race meetings) to 2 months (8 race meetings).
#178
When new, the element will be shiny silver coloured. When you use your engine, you can 'read the plug' - it gives an indication to the how well your mixtures are set and the health of your engine.
If your glow plug's element loses it's nice shiny silver appearance, then the plug should be replaced. If you find yourself needing to replace your glow plug frequently, you need to either adjust your mixtures and/or change to a different heat rating on your plug.
