eXcelerate RC Prodigy Formula 1 >
Like Tree1136Likes
Old 04-16-2026 | 11:41 AM
  #1066
Originally Posted by bertrandsv87
I'd prefer finding a better way to build a track without flappers and without sections a rc car can get under rather than beefing up the car to run in a derby, thereby slowing down performance. Accidents will happen regardless and there is no way to fully bulletproof any rc car for that matter: I've tried and only got slower and slower...
Theres always Oval racing ...... just saying
HD-F1 likes this.
Robbob is offline
Old 04-16-2026 | 11:44 AM
  #1067
Lightbulb
I'd get dizzy very quick oval racing, and send my car in the pits...lol...Not that I haven't done that before racing touring cars...lol...
bertrandsv87 is online now
Old 04-17-2026 | 08:49 AM
  #1068
HD-F1's Avatar
From: In the car taking my kid to another race track.
We have run to cars on the oval track at Apex, it was a blast. I need to get a race together for that, it would be fun!
HD-F1 is offline
Old 04-17-2026 | 10:04 AM
  #1069
We tried it decades ago on our banked oval. ( KN Speedway)
Such a blast but the cars were so fragile you clip the outter wall the front would almost explode lol.
Robbob is offline
Old 04-26-2026 | 11:28 AM
  #1070
Excelerate tires are very light on both rims, raid and excelerate...
Old 05-04-2026 | 10:19 AM
  #1071
Those of you running a ball diff on the P F1 car — Would you mind sharing the parts you used, or your setup? A photo would be amazing.
I just want to measure twice and buy once. TY!
iandouglass is offline
Old 05-04-2026 | 01:25 PM
  #1072
Maybe the Roche ball diff will fit...It might have a slightly longer tube for a bit more left side support...
Old 05-06-2026 | 08:23 PM
  #1073
Casey Belarde's Avatar
Anyone have a good starting point for a asphalt setup?
wayboarder likes this.
Casey Belarde is offline
Old 05-06-2026 | 08:25 PM
  #1074
I have a xray ball diff that works, when I need too, but most of the time I stick to the A12 gear diff
Old 05-07-2026 | 01:11 PM
  #1075
Casey Belarde would you mind taking a photo for me, along with the "full width" measurement there? It would be super helpful. Trying to find a readily available ball diff for outdoor use.
Old 05-07-2026 | 03:34 PM
  #1076
Xray ball diff works too but $$$$$$$....
Old 05-07-2026 | 03:41 PM
  #1077
bertrandsv87 are we all sure that it meets the clearance requirements? AKA maximum vehicle width? It looks the same as the Exotek, or others.
Due to the offset of the Prodigy, I believe it needs a very shallow/narrow diff to meet the 190mm width max.
Old 05-07-2026 | 04:13 PM
  #1078
Correct...It will need to be measured with the rear tires on for that 190mm exact width, but different tires will yield different rear track widths after centering the rear axle. Most clubs won't turn racers away because of a few more millimeters that can be corrected with different offset tires...My excelerate f1 was 190mm F&R with sweep tires and went down to 182mm fronts and 189mm rears with excelerate tires, all stock shims used...It probably will not matter much if the ball diff side of other brands is 2 to 3mm wider than the excelerate F1 gear diff...
Old 05-07-2026 | 06:11 PM
  #1079
TimPotter's Avatar
too wide
TimPotter is offline
Old 05-07-2026 | 06:12 PM
  #1080
TimPotter's Avatar
rc10f6 ball diff works for sure. I have tried exotek, Roche, Team Saxo, schumacher gear diff, all of them too wide.
