Kyosho Mini-Z Series >
Like Tree8585Likes
Old 10-25-2025 | 05:57 AM
  #8251
EMU's Avatar
EMU
IMO, to get accurate data for matching and weeding through cells, you need to discharge around 3A. The charge is less important for matching, so long as it is consistent. Around 1A should be sufficient for 800mAh cells.
I used to store my cells fully discharged between races when I ran NiMh. If stored more than a week, 1 full slow cycle before the race charge cycle.
Criteria for matching, is kind of a mix between all 3. Low IR cells will have the highest discharge voltage. When sorting for stock class, I want the highest mAh above 1.1v. I dont care about total capacity of the cell, but care about capacity that will be offered in the powerband that I am looking for. Generally, a cell that has a high capacity above 1.1v will have a low IR and high discharge voltage for a full discharge. Also, using a higher voltage cutoff cuts down a lot of discharge time from the matching process. I used very different equipment when I was matching a decade ago, (Muchmore CTX-D2 which is a 5A discharge), and cells would fall flat on their face when they started to run flat and IR increased. If matching lower than 2A, you are not getting the data that you need honestly, 3A is ideal to actually have load on the cell so you get a good voltage drop and be able to compare the discharge voltage/capacity in the high voltage range more effectively.
PROMODVETTE and BoxxerBoyDrew like this.
EMU is offline
Old 10-29-2025 | 03:44 AM
  #8252
Originally Posted by MiamizFinest
Has anyone heard of one of these FlySky modules being converted to use ASF?
https://kyoshoamerica.com/flysky-fs-...-82151-11.html
A quick google search shows this for $59- https://supergdrift.com/products/nb4...ng-mxo-rf201-k
I probably have eight or 10 asf receivers in a bag and a few asf chassis.
Traveler2 likes this.
Byebye is offline
Old 11-15-2025 | 11:43 PM
  #8253
MiamizFinest's Avatar
holy shit been looking for something like this forever thank you!
NutDriver likes this.
MiamizFinest is offline
Old 11-15-2025 | 11:44 PM
  #8254
So I bought the kyosho light kit for my Mr-04 and it keeps blinking, I know with the stock radio you rotate the nob and it will go solid but how exactly do I do that if the radio I am running is a 6PV? Any ideas?
Old 11-19-2025 | 05:49 AM
  #8255
On my Flysky Noble it is channel 4. I assigned it to a knob so I can adjust it.
joelisenat is online now
Old 11-21-2025 | 09:56 AM
  #8256
Will try that today
Old 12-05-2025 | 01:41 PM
  #8257
ekim628's Avatar
And this is for using on where? Bearings or comm drops? I am new to oil for 28 scale.
What is EDM?
ekim628 is offline
Old 12-05-2025 | 01:43 PM
  #8258
ekim628's Avatar
Originally Posted by PROMODVETTE
Has anyone tried Al Cass Valve Oil? https://www.amazon.com/Al-Cass-Valve...dp/B002LI4Y92?
This is what I used in slot car drag racing. Some of this mixed with zippo lighter fluid worked really well. Almost as good as EDM fluid!
What is EDM?
_________________
ekim628 is offline
Old 12-06-2025 | 03:10 PM
  #8259
NutDriver's Avatar
Can anyone tell me if the MR04 Evo2 board will work in an MR03RWD? It would be nice to go brushless and sensored.
Thanks!
NutDriver is offline
Old 12-09-2025 | 08:04 AM
  #8260
MR04 has a different servo pot setup so not sure that is gonna be doable. Easier just to buy an MR04 Evo 2.
What is different about the MA030 Evo board? Now the Evo2 version of that board (sensored) is coming out and looks like it shares the steering pot with the MR03 Evo. Are those boards interchangeable?
Old 02-24-2026 | 11:54 AM
  #8261
Default Can mr04 evo 2 board takes 2s lipo?
Anyone knows if the mr04evo2-mz717 (M) can take 2s lipo? Cause for 03 evo there is setting for it but there is no setting on the ics app for 04 evo. Thanks
cup racer is offline
Old 02-24-2026 | 12:16 PM
  #8262
The ICS setting on the 03 Evo is for LiFe, not LiPo. There’s a decent difference in voltage and amperage between the two.
Traveler2 is offline
Old 04-08-2026 | 09:24 AM
  #8263
Hey guys. i found a pn racing 3.0 chassis/roller for 100 bucks is that still worth running ? would be my first lipo car lol . thanks
TheNewGuy13 is offline
Old 04-08-2026 | 03:42 PM
  #8264
I’ve got 3 Wide L setups and an expansion track, plus the CORE timing system, which was the best upgrade when people couldn’t keep count of their laps. Someday when I get over this hobby I’ll sell quite a bit of it, so stay tuned and check out the club site.
TheNewGuy13 likes this.
Bizar is offline
Old 04-27-2026 | 01:00 PM
  #8265
not sure if this is the correct spot to ask this but i was wondering if there is any talk of a track opening in Tucson, AZ? I know there is there is two in phoenix area , like any mini z fan it would be nice to have a shop up the road to practice at when Im free. thank you and sorry if i posted in the wrong spot.
thanks
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
