Ofna hyper .21 8 port race engine >
Old 06-01-2005 | 06:54 PM
tazman34685's Avatar
Default Ofna hyper .21 8 port race engine
Can anyone tell me for what reason does the needle setting on this motor's carb just moves. I have tried two carbs already and now I on the look out for a replacement carb. Is there a known problem with the Ofna hyper .21 8 port race engines?
tazman34685 is offline
Old 06-02-2005 | 08:24 AM
spyspeed's Avatar
It's Must be Worn O ring on the needle,change with New O ring or You can try to soaking the O ring with gasoline.
Hope this help
spyspeed is offline
Old 06-03-2005 | 06:05 PM
Default ofna hyper 8 port O ring
Where do you get replacement O rings for the Carb needles? And will the gas expand out the worn ones?
Old 06-04-2005 | 08:24 PM
Remove the carb and seal it where it attaches to the engine block. Do the same for the back cover. These are known air leak spots.
As for the O-rings, try Ace Hobbies, I just bought some carb O-rings from there today and they had two more bags on the shelf.
Squidward is offline
Old 06-05-2005 | 05:51 PM
spyspeed's Avatar
Yes, it will expand a little..
spyspeed is offline
