Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 02-04-2025 | 01:53 PM
  #12226
Originally Posted by RobS
I've been on the USGT bandwagon for ages but even I am getting sick of the current body rules... My thoughts are if the body isn't modeled off a car on the current GT3 Homologated list (I know, licensing is a factor too) it shouldn't be legal. It's USGTP for the most part now.
Rob, go see the body list on the WGTr thread then with the updated for this season rules....
GregAnthony is offline
Old 02-05-2025 | 12:52 PM
  #12227
Raman's Avatar
Originally Posted by glennhl
Isn't the BWOAH the Aston Martin Valkyrie? https://www.astonmartin.com/en-us/models/valkyrie
Yes it's supposed to be.. but the organisers feel its too far off the real thing. I wanted to run the Exotek GTF which is supposed to be an F50 but it's on the "No" list.
LonnyJ1950 likes this.
Raman is offline
Old 02-07-2025 | 01:52 PM
  #12228
Originally Posted by Raman
Yes it's supposed to be.. but the organisers feel its too far off the real thing. I wanted to fun the Exotek GTF which is supposed to be an F50 but it's on the "No" list.
No kidding? I like the GTF, been running it in USGT, I know it is sold as a USGT body....
Raman likes this.
AsphaltFlyer is offline
Old 03-08-2025 | 07:13 PM
  #12229
NutDriver's Avatar
How is USGT attendance in your area? I race at Soda City RC in Columbia, SC and we haven't had enough to run the class recently. :-(
NutDriver is offline
Old 03-08-2025 | 07:34 PM
  #12230
jjahn's Avatar
I’m new to USGT all my parts aren’t even shipped to my house yet, but I’m confused as to why the body rules would be in the WGTR thread. I checked the rules with the links provided by my hobby shop. They are hosted on the VTA site, last update appears to be June of 2024.
jjahn is offline
Old 03-08-2025 | 08:00 PM
  #12231
MD's Avatar
MD
Very light..
MD is offline
Old 03-08-2025 | 08:26 PM
  #12232
Billy Kelly's Avatar
Tech Prophet
I have driven to Wisconsin few times over winter to run it. It’s very inconsistent locally
Billy Kelly is offline
Old 03-08-2025 | 09:15 PM
  #12233
MonkeyCmonkeyDo's Avatar
More fwd than actual usgt here locally but outdoor asphalt season is just starting so we will see
d
MonkeyCmonkeyDo is offline
Old 03-08-2025 | 10:37 PM
  #12234
TonysScrews's Avatar
Since LMH class popped up, we haven't ran USGT indoors in some time. Last race I seen the class was at the Winter Warrior 5 race at 180 Raceway this past December and they only had 9 entries. The year before they had 20 entries. USGT is one of only two non-Tamiya classes ran at the Brownies Summer Series races at Jackson RC in Jackson, NJ so we shall see if the class still has good attendance. I ran USGT in 2023 but last year in 2024 I ran my FWD instead of my USGT car in that class. This year I plan on running the Tamiya GT2 class instead and Formula One (which is the other open chassis class). I suspect USGT will be dead this summer and they may switch over to LMH. Personally I wouldn't mind running LMH bodies but still run the USGT motor and tires since we all have them. USGT bodies are all over the place and quite honestly the only body everyone runs worth a damn is the BWOAH which in my opinion is a LMH body.
nrtv20 likes this.
TonysScrews is offline
Old 03-11-2025 | 07:48 AM
  #12235
minimusprime's Avatar
hey all, I am getting an xray x4 ready for my (very casual) return to racing. Targeting usgt, but depending on entries, like the above fellow, I may end up in LMH.
That being said, I need to get some race ready lipo batteries for either USGT/LMH or just 21.5 racing in general. Does anyone have any suggestions? I realize this isn't the electronics sub forum... but from looking at setup sheets and reading between the lines, the battery capacity/style is a bit more class specific these days then it was when I was last driving small cars in circles.
minimusprime is offline
Old 03-11-2025 | 10:19 AM
  #12236
Variations in battery capacity choice probably have more to do with weight. 6000mah batteries - from GensAce or similar - seem to be popular in So Cal. If you are in OC, CA then you will find way more USGT racing than LMH around here, sometimes it is the largest class.
STLNLST likes this.
monark192 is offline
Old 03-11-2025 | 10:38 AM
  #12237
NutDriver's Avatar
Default Batteries
For me, the Team EAM 6000mah ulcg battery or its Motiv counterpart are my preference. Low profile, not heavy, and enough capacity for lower power motors.
Old 03-12-2025 | 03:29 PM
  #12238
Check out the Gen's Ace Redline 2.0 6500mah pack. Not an ULCG but also not a heavy brick. Very low voltage drop-off. Perfect battery for USGT.
glennhl likes this.
Old 03-14-2025 | 11:53 AM
  #12239
MikeR's Avatar
Like Monarch mentioned, it's all USGT in OC/LA/SD areas. Haven't seen LMH cars in a while... USGT has enough entries for both sportsman and expert classes so that you can ease into racing again.
MikeR is offline
Old 04-08-2025 | 07:32 AM
  #12240
It is, and in real life the Valkyrie isssss... An LMH. The Protoform Venturi seems to be the hot body at my track and I think it's ugly. Not saying anything about the form because I'm still using a Vittoria. I wish it was all GT1/2/3 based cars.
As far as the tires go, we ran the grey belted ones all last summer in the parking lot and really didn't have any issues. The track is pretty massive so a lot of our final drives were under 3.0. The gearing makes the car even easier to drive. I found that if the car did start to slide at all mid corner, I'd just stay in it and with the lack of torque it wouldn't have enough power to spin out. I was saucing with either liquid wrench, or 3.0 max depending on the prep level of the track that weekend. As the summer went on I did start to have issues with the tires tearing where the glue rib and sidewall met.
I was worried about the grip after seeing a few others the season before have issues with the belted tires on asphalt, so I built the car with tons of mechanical grip from the start and slowly worked away from that through the season. Looking forward to another awesome summer of fun this year. USGT and GT8 FTW!
NutDriver likes this.
Flipside6900 is offline
