Hobbywing OTA Programmer data log, real time data, etc... >
Like Tree1Likes
  • 1 Post By gigaplex
Old 03-03-2025 | 04:21 PM
Default Hobbywing OTA Programmer data log, real time data, etc...
I've been trying to get data logs and the real time data to come up on both a Android and Apple iPad from a new Xerun stock spec 1s. I'll get a partial peak whatever, but that's it. I've reset the programmer, recalibrated the esc, tried it with both the radio on and off and nothing. I'd really like to see the real time data thing. Am I missing something? If certain classes didn't require Hobbywing esc's and motors I wouldn't have them. My Hotwire works great.
bbishop3 is offline
Old 03-03-2025 | 06:45 PM
gigaplex's Avatar
That ESC doesn't support it.
bbishop3 likes this.
gigaplex is offline
Old 03-03-2025 | 08:39 PM
Did you check Hobbywing LCD Program Box (or Bluetooth module) is properly connected and updated?
astonkoena is offline
Old 03-04-2025 | 04:05 AM
Yes. Looks like those features don’t work with the stock spec 1s. Should have checked that before asking this question. Was trying to compare rpm’s on a couple motors.
bbishop3 is offline
Old 03-21-2025 | 05:48 AM
To get the realtime data with all the graphs and so on, you have to run the ESC with the OTA programer attached to it during the run.
Then when you come to a stop, you connect with the app and in datalogs you'll be able to select from ota and see the graphs.
moulip is online now
Old 03-21-2025 | 06:12 AM
gigaplex's Avatar
That depends on the ESC. The latest XR10 Pro G3/G3X doesn't need it plugged in during the run, it saves to the ESC for later downloading.
The ESC they're using doesn't support live telemetry at all.
gigaplex is offline
