Hobbywing Justock ESC >
Like Tree1Likes
  • 1 Post By whopper14
Old 10-23-2024 | 05:59 PM
Default Hobbywing Justock ESC
I had to splice the 3 wire ribbon cable which connects to receiver. I think I made a good splice but esc is not working. Red light blinks and beeps continually like its in calibrate mode. There is a chance I plugged in backwards to receiver, all wires are black. Is there a chance I blew the esc by plugging in backwards to receiver or suspect splice? When I first powered car up the servo worked but motor did not. Now just flashing red light and beeps. I was able to connect programmer to esc and seemed to read properly. Is it possible to blow the esc by plugging in backwards to Juststock esc?
whopper14 is offline
Old 10-23-2024 | 08:25 PM
gigaplex's Avatar
Plugging in backwards to the receiver shouldn't have damaged it. The splice may not be good.
gigaplex is offline
Old 10-23-2024 | 09:20 PM
Thanks, that's what I was thinking. Check splice tomorrow.
Old 10-24-2024 | 08:35 AM
did you re-calibrate the ESC or is not even letting you get into calibration mode?
billdelong is offline
Old 10-24-2024 | 09:26 AM
Fixed, had a bad splice. Had to remove a couple layers of shrink but all is well. Those were some pretty small wires to splice!
RetroThutmose likes this.
