Schumacher cougar LD3 >
Like Tree134Likes
Old 03-28-2024, 02:37 PM
  #316
BP
Can anyone tell me what servo horns work well on this car? Also for the L1R if you know.
BP is offline
Old 03-28-2024, 02:52 PM
  #317
staiguy's Avatar
the aerox one works best, AX009 - 25t AX010 23t. I have a protek one that works, but after grinding down some of the horn so it could swing without hit anything.
BP likes this.
staiguy is offline
Old 03-28-2024, 09:00 PM
  #318
Trader Rating: 79 (99%+)
I built my buggy with the longest reverse offset Core RC horn. The drag link sits under the servo so some creativity has to be used. I didn’t grind anything for proper fitment of my AgFRC SA33 servo and zero shims on the spacing. I hope this helps, and if you need more help just ask.
BP likes this.
Raul Garcia is offline
Old 04-03-2024, 11:37 AM
  #319
rcfiend's Avatar
Trader Rating: 42 (100%+)
Do AE, and Xray wheels work on the LD3?
rcfiend is offline
Old 04-03-2024, 01:17 PM
  #320
Trader Rating: 125 (100%+)
Yes
rcfiend likes this.
kwiksi is offline
Old 04-06-2024, 09:46 PM
  #321
RazorRC's Avatar
I believe the AE carpets are the same, but the dirt wheels are a little different.
RazorRC is offline
Old 04-06-2024, 09:58 PM
  #322
BP
BP is offline
Old 04-09-2024, 01:47 PM
  #323
BP
Anyone have a hardware list? I’m trying to put together a list for titanium ball studs and can’t find the specs anywhere.
BP is offline
Old 04-09-2024, 03:09 PM
  #324
staiguy's Avatar
The manual and exploded sheet have part # for ti ball studs. They dont give you specifics like thread size or ball size but the schumacher site lists most of the info.
x2 - U4274 [4.3mm diameter ball stud with 6mm length] ti part - CR280
x8 - U4275 [4.3mm diameter ball stud with 8mm length] ti part - CR282
x4 - U4700 [?Not listed on site. Contact schumacher?] ti part - N/A
x2 - U8559 [5.5mm diameter ballstud extra long length] ti part - N/A
x1 - U4850 ***Steering ballstud***
staiguy is offline
Old 04-09-2024, 07:51 PM
  #325
BP
Thanks that is exactly what I needed.
BP is offline
Old 04-14-2024, 03:00 PM
  #326
tony montana's Avatar
Trader Rating: 76 (100%+)
Any new dirt setups for the car?
tony montana is offline
Old 04-15-2024, 12:47 AM
  #327
Taz_S's Avatar
what front wing is that?
Taz_S is offline
Old 04-15-2024, 03:23 AM
  #328
Looks like one of Lee's own LMR ones
Headling is offline
Old 04-16-2024, 06:33 PM
  #329
BP
I’ve heard the Pro’s prefer the aluminum front bulkhead over the brass. Does the brass put the weight to far forward on the chassis?
BP is offline
Old 04-16-2024, 07:25 PM
  #330
staiguy's Avatar
Imo the brass bulkhead is too heavy and a little too far forward. It's more weight in an up-down motion, more front grip overall. The radio and servo tray is just far enough it's more diagnol weight transfer, more brake/corner grip.
BP likes this.
staiguy is offline
