Schumacher cougar LD3 >
Like Tree148Likes
Old 11-08-2023, 08:28 AM
  #46
staiguy's Avatar
Running a LD but this thing is solid! More bends then breaks and I've had head on collisions, barrier hits, horrible landings, head on collision with the wall... (it came out of nowhere i swear!). Always seems to either bounce back or I can at least finish the race. I had a shock pop off BUT I was still able to finish the race. I lost 2 places but its better than a DNF due to a broken front tower. I went with titanium turnbuckles and that either moved the forces to the hinge screws (U4738) or ball cups (U4704) and those got bent. The other day my servo got stripped but it wasn't the most solid choice. Decent but a plastic top, not aluminum. Also one plastic front hub broke after someone hit me during a turn . I run 17.5 and have a mix of plastic, aluminum and brass depending on if i need the weight savings vs durability.
Also is there a better bottom shock cup? My springs sometimes pop off the cup from the low ride height.
staiguy is offline
Old 11-08-2023, 09:09 AM
  #47
Originally Posted by ChocoTaco73
With a shorty servo and 2 fans:
wow!
CMB1991 is offline
Old 11-08-2023, 09:41 AM
  #48
ChocoTaco73's Avatar
Originally Posted by CMB1991
wow!
With carpet tires it weighs 1468g, so 6g underweight for a 2whl lol
Back on topic, I have bent a couple of the captive ball joints I was using on the inside front camber link location. When running 4-5mm of shims it's not hard to do with the steel ones. Have since switch to the titanium versions and haven't had a problem.
HOTROD716 likes this.
ChocoTaco73 is offline
Old 11-08-2023, 10:29 PM
  #49
fa7boyrc's Avatar
Originally Posted by CruiseM
@ fa7boyrc:You will need:
U8620 Alloy Layshaft - LD3
U8621 Layshaft Bolt - LD3
U8399 Outer Slipper Plate - L1R
U8631 Outer Slipper Plate - LD3
I am one of those who don't run aeration I prefere bladder.
For the shock bottoms in the reaer there are options. You can also run the combination of U8428 5.5mmball and U7431 Or if you want a screw:U7367
O-Ring on hex never was a problem .
There will of course a pictured build in the next week.Just be patient.
Cruise
thanks!
fa7boyrc is offline
Old 11-08-2023, 10:31 PM
  #50
fa7boyrc's Avatar
Cruise
why do i need two outer Slipper plates ?
fa7boyrc is offline
Old 11-09-2023, 07:12 AM
  #51
Because they used the L1R outer plate as the inner on the LD3
fa7boyrc likes this.
CruiseM is offline
Old 11-09-2023, 12:55 PM
  #52
Pistol123's Avatar
Default Lee Martin build video
Lee Martin did a build video on fb in the UK, part 1 was a good watch with quite a lot of useful tips and hints etc:
https://fb.watch/obICeEMyTo/
ChocoTaco73 likes this.
Pistol123 is offline
Old 11-09-2023, 04:29 PM
  #53
Trader Rating: 380 (99%+)
Who sells the front scoop/wing in the photo above?
Also, does the LD3 come with a rear wing? Just opened my box and didn’t see one.
jonski is offline
Old 11-09-2023, 04:32 PM
  #54
EJF
EJF's Avatar
Trader Rating: 41 (98%+)
https://www.discountrcstore.com/aero...-wing-ld2.html
EJF is offline
Old 11-09-2023, 04:33 PM
  #55
Thanks Eddie!
jonski is offline
Old 11-09-2023, 10:00 PM
  #56
fa7boyrc's Avatar
ok, thanks!
fa7boyrc is offline
Old 11-11-2023, 07:01 AM
  #57
tony montana's Avatar
Trader Rating: 76 (100%+)
Anyone have any pics on putting the fan by the motor for 17.5?
tony montana is offline
Old 11-11-2023, 08:35 AM
  #58
HOTROD716's Avatar
I use the exotec around the fan mount. Keeps the motor cool.
HOTROD716 is offline
Old 11-13-2023, 09:04 PM
  #59
staiguy's Avatar
Just put in a pre-order!!! Can’t wait. Haven’t had a brand new buggy since a rc10b4! Hopefully they come in soon.
Definitely going to watch that build video for tips. Any other build tips?
staiguy is offline
Old 11-21-2023, 06:56 PM
  #60
First race this past weekend with the ld3m on indoor clay. First impressions were pretty good. Was using a mix of Cav's world's setup. Car has a ton of steering. In the main I did break the car. Coming out a corner on the straight car got wicked loose and hit the pipe full throttle. Broke the front camber link, and a rear arm so I didn't finish. But I did buy when leaving the track AE 13mm blue front and rear gray springs AE spring cups and shock ends. I ran ran the stock kit springs. Car definitely has potential, I would like to calm the car down some and have more grip
Taz_S likes this.
