Like Tree323Likes
RC10T6.4
Old 07-13-2023 | 09:55 AM
  #121
Originally Posted by TimF
On previous 6 series trucks the steering rack (going to aluminum vs the stock plastics) has been a helpful upgrade. Once you bend the first tie-rod, go to Titanium. They offer different weighted front bulkheads (made of different materials) as well. My 6.1 was a durable truck, hoping the 6.4 (once I get it built) is just as durable..
Makes sense. I can feel a little slop in the steering, but it is not too bad.
dmackerman is offline
Old 07-13-2023 | 11:01 AM
  #122
jabroni racing's Avatar
Originally Posted by Cinnabun
Couple bling parts installed.. FT servo brace and FT carbon motor plate.
link for motor plate :-)
jabroni racing is offline
Old 07-13-2023 | 11:16 AM
  #123
Kraig's Avatar
Super Moderator
Motor plate.
https://www.associatedelectrics.com/..._carbon_fiber/
jabroni racing, BP and Cinnabun like this.
Kraig is offline
Old 07-13-2023 | 03:52 PM
  #124
petersen114's Avatar
Ugh. all this is making me want the new truck.
petersen114 is offline
Old 07-14-2023 | 04:19 AM
  #125
After 3 club races with the t6.4, I can say the upgrade was completely worth it. It feels more stable and I can throw it into the turns harder and maintain more speed through the turns. Traction rolling with the 6.2 was a major issue, I have yet to traction roll the 6.4 even when I over drive the truck trying to make up lost time.
petersen114 likes this.
Cinnabun is offline
Old 07-14-2023 | 07:05 AM
  #126
ollie 45's Avatar
What setup are you using and what surface.
I will be picking one up for the up coming fall/winter season. I totally agree with the traction rolling issue, was hard to get a perfect setup that you can drive hard on sharp corners.
ollie 45 is offline
Old 07-14-2023 | 07:27 AM
  #127
I’m running a setup that I came up with myself. Give me a little bit to go through the truck and I’ll throw it on a setup sheet and post it
ollie 45 likes this.
Cinnabun is offline
Old 07-14-2023 | 10:59 PM
  #128
RazorRC's Avatar
I'm most curious on what ride height and shock package are you running? I can't get mine to land the way I want, not sure if I need more droop, different pistons or what. Running 19mm ride height, kit shocks with 37.5wt front, 35wt rear, +1 internal limiter in the rear.
RazorRC is offline
Old 07-17-2023 | 10:40 AM
  #129
On the T6.2 with 13mm shocks on black carpet, we run 2.5mm pistons:
- Front 2x1.7/37.5wt/truck gray/29mm stroke/+0 eyelet/4mm external limiter
- Rear 2x1.8/32.5wt/truck white/36mm stroke rear/+0 eyelet/4mm external limiter
- 16mm Ride Height (body off)
Ride height is key to limiting traction roll. I could never get the truck lower than 19mm with the old shocks.
Also tires: Jconcepts Fuzz Bite rears (mounted less aggressive direction) and Swagger fronts with Sidewall GLUED up to the first rib.
I'm going to be trying 2.5mm 1.6 front pistons when I build my T6.4. Tried them on a friends buggy last week and they were great.
RazorRC likes this.
MrLean is offline
Old 07-18-2023 | 05:16 AM
  #130
see attached set-up sheet. Might not be for everyone, but this is working for my local black crc carpet track.
File Type: pdf
RazorRC likes this.
Cinnabun is offline
Old 07-18-2023 | 08:33 AM
  #131
El_Rando's Avatar
i know it's not what they're mint for, but has anyone tried bashing one of these trucks yet? BMX trails? skate park? heck just around the yard? wondering how well they work for that kind of usage.
El_Rando is offline
Old 07-18-2023 | 11:37 AM
  #132
Did you drill your own pistons? I think AE only makes the 3-holes in 2mm thickness, correct? I tried them on buggy and didn't love them. I always seem to like the 2.5mm better.
MrLean is offline
Old 07-18-2023 | 12:05 PM
  #133
yes, they are Avid machined blanks and I use a schelle drill.. I have the same piston setup in my b6.4. I like the 3 hole for more initial dampening and the 2.5mm has more pack.. the truck lands better without slapping and allows the truck to lean but not completely roll the chassis over in the corners.
MrLean likes this.
Cinnabun is offline
Old 07-19-2023 | 04:04 AM
  #134
Definitely wouldn't be my first pick for bashing but they are durable on the track
El_Rando likes this.
76jimmy is offline
Old 08-05-2023 | 08:54 PM
  #135
so whats the deal with the rear hinge pins spacers not fitting right and needing to be sanded down for the arms to move smooth?? had same issue with B74.1D, and now the T6.4 you would think by now crap like that would've been ironed out..
