Like Tree2991Likes
1/12 forum
Old 05-12-2022 | 05:13 AM
  #49351
hanulec's Avatar
Originally Posted by simple
Whatever is left of Protoform??- they seem so have moth-balled development - haven't seen anything new for 12th scale for a few years - and the only body listed on their site is AMR-12.......
They had the durability (albeit heavy) of the polycarbonate nailed down - the thickness was perfect for taking a beating while I figured out the tuning of my cars....I miss that. The relatively "new-to-the-scene" body developers seem to be more expensive - and simultaneously fragile. I understand that there is a sacrifice for performance vs durability - but I've not been 100% pleased with current offerings.
i'd recommend you check out the multi-time WC and national championship winning body - Mon-Tech M20 - for SS and Mod 1/12th ... its the most popular body right now.
hanulec is offline
Old 05-12-2022 | 07:24 AM
  #49352
Interesting....so you can use the m20 for mod and stock
phatboislim is offline
Old 05-12-2022 | 09:10 AM
  #49353
Question about side wall gluing? Do you glue both sides of the wheel front and back? I did hear that you do want to use thin ca. Is this correct? Apparently I am using the wrong search words to find any videos. Any help would be appreciated. Thank you
jmetcalf is offline
Old 05-12-2022 | 09:39 AM
  #49354
hanulec's Avatar
Outside only
Do yourself a favor and do not round your tire edges -- it makes sidewall gluing much harder to pull off
jmetcalf likes this.
hanulec is offline
Old 05-12-2022 | 09:25 PM
  #49355
JeffofSpace's Avatar
For clarity: you only glue the outside of the front tires, not the rear tires.
JeffofSpace is offline
Old 05-13-2022 | 12:07 AM
  #49356
OVA's Avatar
OVA
If you glue side wall of the rear tires .it will allow to less rear traction or side tire bite
OVA is offline
Old 05-13-2022 | 10:14 PM
  #49357
Or could use less sauce area. Don’t know, any time I’ve seen someone glue the rears it was a disaster.
Old 06-04-2022 | 05:16 PM
  #49358
What would cause your car just to loop out in turns. Inconsistent. Can run 20 laps and it’s fine then all of a sudden it will just loop out. 17.5 foam car
ronallen is offline
Old 06-04-2022 | 07:33 PM
  #49359
That sounds like gunk buildup on the chassis or catchy wheel bearings, either fronts or rears, that is if everything else checks out....
bertrandsv87 is online now
Old 06-05-2022 | 07:31 AM
  #49360
What surface are you running on? It could be as simple as too much front compound and the rear compound wears off before the front. Also, check your outside edge of the rear tires to make sure they are in good shape. I have seen too much rounding of the rears cause spins due to the way a spool corners by lifting the inside rear. This is all assuming everything else, like tweak and such are good.
chensleyrc1 is offline
Old 06-06-2022 | 11:12 AM
  #49361
MC Hamilton's Avatar
I have seen people use too much steering lock or crack a rim on one side and the rim hits the steering linkage at lock. In the beginning of the run, you may be turning the wheel a little less then going to lock 20 laps in and catching the inside tire. That will loop the car for sure. Also have seen the body get bent or the upper of the front fender crack making the body more flexible up and down - this hitting the wheel while turning, stopping the inside front and looping the car.
MC Hamilton is offline
Old 06-06-2022 | 04:54 PM
  #49362
That m20 body is money. Its likely my new stock body. At least for my current track and setup
hanulec likes this.
  #49363
Old 07-12-2022 | 01:39 PM
  #49364
RacinJ's Avatar
Is there going to be a 2022 1/12th scale world championship? I haven't seen anything about the event.
RacinJ is offline
Old 07-12-2022 | 02:01 PM
  #49365
oldfool's Avatar
Originally Posted by RacinJ
is there going to be a 2022 1/12th scale world championship? I haven't seen anything about the event.
https://www.ifmar.org/calendar/
14 - 18 September
IFMAR WC 1/10 Electric On-Road
Gubbio, ITALY
Is Pro 10 run at IFMAR worlds?
oldfool is offline
