Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 01-28-2022 | 06:51 AM
  #3076
This is the same chassis now.
Big Willy likes this.
TurboThirdGen is offline
Old 01-28-2022 | 06:54 AM
  #3077
DirkW's Avatar
Ok... IMHO, for a runner, this is actually too much blue. It's unnecessarily heavy (yes, aluminium, while light for a metal, is usually quite a bit heavier than plastics or carbon fiber) plus aluminium bends, while plastic usually either keeps its shape or breaks (easy to see). But a slightly bent metal part can escape visual inspection yet still severely affect handling. So, just as a well-meant advice: never use aluminium A-arms, that's a part where plastic is actually superior, also, CF would be better than aluminium for both bumper brace and damper bridges (lower weight high up, and still good-looking).
TurboThirdGen likes this.
DirkW is offline
Old 01-28-2022 | 07:03 AM
  #3078
All things I learned after spending wayyy too much on a TT02
See above post. Honestly the only thing that hasn't bent is the lower a-arms. They are relatively robust. And the reason it veers off in the one vid is because the rear of the body "parachuted" lol.
It's not as heavy anymore, and I'm working on a diffuser to streamline the sides and back. You can see the front one I 3d printed.
This thing is so stupid fast its insane. I had it over 60mph on 3s, and now I've changed the gearing to ( I don't quite remember) the smallest possible 48p spur gear you can fit on the high speed gear set, and I think a 47t pinion. It hits about 60mph on 2s at 3/4 throttle now.
Old 01-28-2022 | 07:25 AM
  #3079
DirkW's Avatar
You're neither the first nor the last person who did that, be assured. It's what someone at our track once christened "bashers' disease" (i.e. putting every available hop up into a car, regardless of its usefulness, or even contrary to it). What you could still do (improved looks, a few grams of weight reduction, with only very minor consequences in durability), if you still want to drop a couple of bucks into that car, is a Hiro-Seiko (or other manufacturer) aluminium/titanium hex screw set for the car. All that blue and still the ugly Tamiya standard screws looks like s job half-done.
DirkW is offline
Old 01-28-2022 | 07:27 AM
  #3080
You are quite correct there. I've been looking at that titanium set for awhile now lol.
Old 01-28-2022 | 07:34 AM
  #3081
DirkW's Avatar
This is actually something I ended up putting into all my cars (except my SCX - so far). My Off-Roaders get the full titanium screw sets and On-Roaders get aluminium/titanium sets (with the aluminium screws in the correct color (light blue for my Tamiyas and orange for my Xrays). Love the looks, and it reduces weight by quite a few grams, if you replace all screws (whether it's really worth the cost just for weight reduction...? Probably not. But that plus looks... for me it's totally worth it, even when made (good natured) fun of by my fellow club racers sometimes .)
DirkW is offline
Old 01-28-2022 | 07:44 AM
  #3082
I'll be honest; I'd be buying for looks haha. Weight reduction is a bonus!
Old 01-28-2022 | 10:01 AM
  #3083
DirkW's Avatar
Instead of just talking about it, I should maybe just show my TT-02 Type SR :
Raman, Big Willy, jgil089 and 2 others like this.
DirkW is offline
Old 01-28-2022 | 06:52 PM
  #3084
Raman's Avatar
Originally Posted by SteveM
This hobby can be addictive at times, there is no doubt. My TT-02 White Special started box stock but like most people I was unable to resist the allure of the blue bits. I went for the Yeah Racing parts as they are less expensive than Tamiya but work just as well. Mine has the steel front & rear joint cups, steel CVD's, alloy ball bearing steering, alloy main shaft joints, alloy front and rear upper adjustable arm sets, adjustable motor mount, solid axle diff insert, front upper bumper plate, a set of threaded blue shocks, and a set of 3 degree rear hub carriers. I did use the blue Tamiya center shaft and the Tamiya High Speed Gear adapter, plus a set of VBC Racing clamping wheel hexes. I also had a spur gear cover 3D printed so that I can use larger pinion gears needed when running brushless motors. I topped it off with a McCallister Mustang GT body and have a set of Gravity RC USGT tires mounted.
With all local R/C racing cancelled due to the pandemic, she sits on a shelf waiting for better days ahead. Seems silly I admit but I am weak.
I had enough spares to make a basic TT02 for display purposes. It has now evolved into a house guest TT02 for my sons best friend. Pretty soon it will have some blue crack
Big Willy and TurboThirdGen like this.
Raman is online now
Old 01-28-2022 | 07:11 PM
  #3085
Big Willy's Avatar
That's a beauty, Dirk!!
Big Willy is offline
Old 01-29-2022 | 05:27 AM
  #3086
That thing is beautiful!
Raman likes this.
Old 01-29-2022 | 05:28 AM
  #3087
So I guess those nylon bushings lasted long eh? LOL
Old 01-29-2022 | 08:26 AM
  #3088
Raman's Avatar
LOL! They’re still on there lol.. but my sons type S is due for a bearing refresh after 6 years.. so I’ll toss those onto the guest TT 🤦🏻
Raman is online now
Old 01-29-2022 | 08:35 AM
  #3089
Try this.
80% silicone bearing oil mixed with 20% PB Blaster Graphite spray. Soak for 24-48 hours and agitate the mixture every few hours, or when you remember.
Now you've got sealed bearings that clean themselves. So smoooooth.
When I was younger I used to use the Graphite lubes on my BMX bike bearings. I felt like it made me faster
It definitely made the bike coast a longer distance.
Old 01-29-2022 | 05:24 PM
  #3090
Originally Posted by Big Willy
Man, I was buying a TT02 Type S online, and turns out they were sold out but still listed. I got to thinking- the cost of the type S is like 45 bucks off the price of the TA08 Pro, not counting the traditional 150 bucks of Tamiya go fast/look fast blue stuff. I gotta ask, why even buy the TT02? Other than TCS races, I don't see the point. Enlighten me, guys.
If you want to go full on, get a real TC. If you want to embarrass people with more money than skill, TT 02 is very capable in the right hands, just don't go down the rabbit hole with mods.
We race this class as a box stock +bearings class. All driver, car doesn't help you and you can't tune to win. Shows who can wheel and sharpens skills because it's all on the person who is driving it. That's the magic, crazy tight super fun racing chassis that comes nearly complete out of the box for the price of a TC ESC. We have more fun with this class and better racing for 1/4 the cost.
dman18t is offline
