VXL-3S
Old 12-19-2021 | 12:04 PM
Default VXL-3S
Hi everyone I'm having issue here with my vxl-3s the ESC thinks that the switch is stuck on I thought maybe it it switch problems so I change the switch out myself and the problems still there.
I have contacted traxxas only thing they told me is to buy new one.
I've do some research and haven't really find posts that similar problems most I've people issue is switch and replaced that and everything buck to work but in my case it wasn't the problem I guess.
so what else could it be?
if turn it on the ESC would work for few seconds and it thinks that switch I been pressed and do it's own thing like lipo cut off disable or sometime it would under into driving mode or recalibration mode.
CLASH is offline
Old 12-24-2021 | 04:17 PM
Try needle nose pliers to unpress it- otherwise you need to take it apart and get a spring under it or you can make anything else to make the button unpress.
Rccarperson is offline
Old 12-25-2021 | 01:33 PM
did that fix it?
