Traxxas 2wd Slash Thread >
Like Tree31Likes
Old 07-22-2021 | 04:41 PM
  #3151
What would be a good replacement battery for a VXL Slash 2wd? I want to stay with a 2s battery. Thanks, Dave.
twistert1 is offline
Old 07-23-2021 | 10:13 AM
  #3152
I've had great luck with the SMC packs. Great bang for the buck in my opinion.
https://www.smc-racing.com/index.php...rice&order=ASC
--Alex
alexo35 is offline
Old 07-23-2021 | 10:27 AM
  #3153
alexo, thanks for the help,
Old 07-23-2021 | 11:40 AM
  #3154
I bought some of these last year and so far have had great luck with them. They all take pretty close to the rated capacity when I charge them and I haven't seen any degradation after a year of use.
https://chinahobbyline.com/shop/detail/351
twistert1 likes this.
kutless is offline
Old 09-28-2021 | 08:43 AM
  #3155
swerv512's Avatar
Trying to setup my new 2wd slash for spec carpet racing (OEM electronics and tires) and I'd like to upgrade the stock shocks to GTR Long and XXLong on my LCG chassis. What aftermarket or non- Traxxas springs will fit on GTR shocks? Team Associated, TLR, Proline, VG???
thanks in advance.
swerv512 is offline
Old 09-28-2021 | 09:10 AM
  #3156
thanks in advance.
You will need 13MM Springs. Losi TEN SCTE Springs will fit. Buy the whole set. Easier to tune when you have multiple Springs to choose from.
Losi: Front Racing Spring Set: TEN: Losi (LOSB2959)
Losi: Rear Racing Spring Set: TEN: Losi (LOSB2963)
swerv512 likes this.
MaX-D is offline
Old 09-28-2021 | 01:34 PM
  #3157
When I was racing my 2WD Slash In the modified class on outdoor clay against TLR and associated trucks, the GTR shocks with the Losi TEN SCTE Springs made a huge difference in how the truck handled. Once I got the suspension dialed in, there were a lot of drivers getting mad because they got beat by a Slash. LOL 😆 🤣
MaX-D is offline
Old 09-29-2021 | 09:12 PM
  #3158
ta_man's Avatar
Associated SC10 4X4 (13MM) springs also fit Traxxas GTR shocks and have slightly different spring rates from the Losi springs.
I think the Tekno ET410 springs will also fit but I haven't tried them yet.
ta_man is offline
Old 09-30-2021 | 10:59 AM
  #3159
swerv512's Avatar
I need to limit the downtravel on the new GTR shocks. They're a bit longer than the stock ultra shocks. Are there any easy solutions? Can I just use fuel tubing or should they be hard?
swerv512 is offline
Old 09-30-2021 | 02:39 PM
  #3160
RazorRC's Avatar
Definitely use hard plastic, fuel tubing will eventually tear. There should be shock spacers in the GTR rebuild kit, those will match the existing rear ones nicely.
RazorRC is offline
Old 09-30-2021 | 02:48 PM
  #3161
RazorRC's Avatar
Yup, the Tekno ET410 springs fit the GTR shocks nicely, I'm running a set on mine, you can get them in pretty stiff rates (red or orange).
RazorRC is offline
Old 09-30-2021 | 08:08 PM
  #3162
Is it weird i'm still running the Ultra shocks on my race truck? Only thing i did with them is swap out the shafts to the Ti-Ni shafts, and running a slightly heavier oil.
if patrick rotisser can TQ INS11 with stock springs, they can't be that bad.
skife is offline
Old 10-02-2021 | 09:40 AM
  #3163
St. George's Avatar
Does anyone know whether the new Drag Slash transmission will work on a normal Slash 2wd short course truck?
St. George is offline
Old 10-02-2021 | 05:57 PM
  #3164
ta_man's Avatar
I called Traxxas to ask and they said yes.
ta_man is offline
Old 10-04-2021 | 04:46 PM
  #3165
swerv512's Avatar
https://www.facebook.com/JConcepts.I...8375084539700/
only reason I upgraded to gtr Shocks was because the stock ultra shafts bent on the first few runs. Otherwise, the aluminum shock caps on ultra Shocks worked ok. I feel the shock package is a little more "supple" with larger volume Shocks tho... not needed but nice to have
swerv512 is offline
