Servo wire
Old 02-04-2021 | 12:51 AM
Default Servo wire
Anybody shorten there servo wires or a hobby shop that does it?
Aggie2014 is offline
Old 02-07-2021 | 03:21 PM
The easiest way is to cut down the servo wires and replace the connector. Most electronics and hobby shops sell the replacements.
These can be crimped with basic pliers, but using the proper crimping tool gives a stronger result. You can also solder the connectors for added strength and conductivity, but you need to be careful not to bulk up the pins too much or they wont fit back into the plastic housing.
Rogue_Aus is offline
Old 02-10-2021 | 07:34 PM
gigaplex's Avatar
RAB Hobbies does servo wire shortening. I'd imagine most do. Ask your local place if they do it.
gigaplex is offline
