General offroad setup  Lots of great info! >
Like Tree10Likes
Old 11-02-2020 | 11:08 AM
  #31
Originally Posted by lexusbest
It looks like it's a common change on yokomo cars, being up to 1mm rear and 3mm front. I have seen this on every type of surfaces, from lowest grip dirt to highest dirt carpet
Just because there is a shim somewhere doesn't mean changing a shim makes an adjustment. Go ahead and try different shims and you will see it doesn't change the handling of the car.
How would changing how far the shocks are tilted change the handling as an adjustment?
The setup sheet for a YZ2 does not have a place to list these shims as an adjustment, where are you seeing that different shims are being used?
waitwhat is offline
Old 11-02-2020 | 01:56 PM
  #32
lexusbest's Avatar
What you said makes sense. I just sow many pics from factory drivers running different variations of shock aligment on the tower.
When you see that on many pics it might be something not to overlook, that's why i came here and ask
lexusbest is offline
Old 11-02-2020 | 02:31 PM
  #33
I can't speak for the factory drivers but definitely seen the ae shocks used on the yz. This might require shimming if they use short shock standoffs, it keeps the shock cap from hitting the tower and puts the shock back inline close to kit.
trf211 is offline
Old 11-02-2020 | 02:41 PM
  #34
lexusbest's Avatar
Who the heck would run AE shocks on a yokomo. Nevermind, this is with stock yz2 kit
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
