Carpet differences
#16
I have taken to using the schumacher honeycomb tires. In general these tires I don't need to sauce very often, and they wear quite well and hook up well. As I mainly get up there for series races and maybe a practice day a month or so, the tires I have been using have lasted probably a couple of years now and are still going strong, tread on the front just starting to show a lot of wear.
Part of it can be for sure I also running my vehicle in a 13.5 configuration but have used it in mod with a 6.5T motor (class is full mod but track size 13.5s are common). But overall I feel the tires last well and work well too.
Personally, I have wondered on turf if those proline hooser tires could be a good spec tire. The traction wouldn't be insane like pins for sure, bit of drift, but if anything from what we seen right now indoors with similar kind of tires, you get a lot of runs with them. Bit of drift also can give a bit more "offroad" feel. The tires also have molded into the tire sidewall the compound too. If folks were willing to accept those traction trade offs, could be a nice option. Heck that schumacher tire that looks like an HPI Xpattern tire could be an option too and offer longer wear.
One other thing, since guys do a variety of sauce voodoo to really soften things up, have wondered if a tire compound could ever be made that if you did any of that (outside of some accepted sauce relative to the rubber), the tire would change color showing it was "tampered with" and be illegal.
Ultimately though it all depends on what folks are willing to accept for traction levels.
#17
The Slash treads perform well enough for turf and last for many months of use, at least for slower speeds so anything that has some sort of pin will work, I'm thinking a thick heavy block/pin medium compound that is designed for a RTR should do well, pick any brand that sells buggy tires separately and that should work fine, maybe something like these HSP tires perhaps?
#18
heck with that kind of setup, assuming they will bite reasonably well on the track, maybe some jconcepts nessis,lockness, or go back to some schumacher mini spikes? Heck I bet old school panther step pins could work lol. that price those on those tires looks really good if you spec'd them and got a bunch in.
But, one thing I am thinking personally is that kind of like dirt, tires that aren't pin style only have so much traction, so you can only put so much power down. It may show some benefit then as far as wear and tear on the cars, track, and better throttle control too.
when the weather gets going for outdoor may give some non-standard turf tires a try just to see what is what for life, etc.
#19
I am loving office style carpet. It has the perfect blend of high traction and good tire wear. I find Ozite over -rated. Chews through too many tires, unless the track has a rule against aggressive tires.
11Likes
