Like Tree2991Likes
1/12 forum
Old 04-25-2019 | 09:48 AM
  #47491
how heavy is that esc
phatboislim is offline
Old 04-26-2019 | 07:20 PM
  #47492
DesertRat's Avatar
Per their website, it weighs 47g empty, without wires or fan. Case Size(with out fan) - 32.9 x 34.6 x 21mm
DesertRat is offline
Old 04-28-2019 | 09:55 AM
  #47493
nashrcracer's Avatar
SRG-HR sanwa servo anybody got pictures of how they are mounting them? I use the big servo saver and I'm not sure I could do that with this servo. thinking of getting a graphite spacer made up for it.
nashrcracer is offline
Old 04-28-2019 | 10:00 AM
  #47494
Dirla, I am running the X-ray saver on mine. Got it shimmed down as close to the chassis, but still "floats" on my X1218. I can get a pic later, I am at work at the moment.
nashrcracer likes this.
chensleyrc1 is offline
Old 04-28-2019 | 11:42 PM
  #47495
DesertRat's Avatar
I have an Xray pan car servo saver in my 1/12, and the coil spring that it used is terrible and the car would lose the trim with anything but the lightest bump. I had to tear apart another Xray medium(?) servo saver for touring car and swap the band-spring into the pan car servo saver plastic. After that it worked great... but it means I think I have $35 wrapped up in a servo saver.
Old 04-29-2019 | 10:26 AM
  #47496
That is not the servo saver. Many including me think the xray saver is the best for 1/12. A servo not centering is usually the servo.
sdunnmcp is offline
Old 04-29-2019 | 12:42 PM
  #47497
jetnjme's Avatar
ck25, r1 wurks, protekrc, sanwa, futaba, fenix gear diff, hot race tires (rear), crc spec front tires, protoform BMR12
Giorgio and AngryRog like this.
jetnjme is offline
Old 04-29-2019 | 02:52 PM
  #47498
DesertRat's Avatar
That was not the case this time. I could move the plastic relative to the spring and it stayed there. After I swapped the coil spring for the band type spring, it fixed it.
Old 04-29-2019 | 04:45 PM
  #47499
I don't think your was built correctly then, there are no coil springs in a X-ray Servo Saver, it comes with 3 band springs for the stiff version, 4 band springs for the x-stiff. There was a old version that "may" have had a spring, but was not one you assembled, it was more like a Kimbrough, but haven't seen one of those in years.
Old 04-29-2019 | 05:47 PM
  #47500
silden's Avatar
You probably didn’t read his post correctly.
He is using the Xray PanCar Servo saver and not the larger TC hard or X Hard saver.
The PanCar version is smaller, but the spring is rather rubbish.
silden is offline
Old 04-29-2019 | 08:43 PM
  #47501
JeffofSpace's Avatar
I like the Kimbrough smaller version. Allows for flatter steering links. Have not had issues in stock or mod. You do have to ream the holes to fit the m3 ball ends, and trim the saver body so the cups don’t hit...but hey, this is 12th scale.
ShadowAu and LonnyJ1950 like this.
JeffofSpace is offline
Old 04-29-2019 | 10:48 PM
  #47502
Has anyone tried and liked the MuchMore 1s speedo? Or is the hw pro the best thing going?
Azsmartbet is offline
Old 04-30-2019 | 08:50 AM
  #47503
DesertRat's Avatar
I'm pretty sure I didn't hallucinate there being a coil spring inside of the servo saver.
Old 04-30-2019 | 08:51 AM
  #47504
For outdoor asphalt is anyone using anything other than PARAGON for the tire sauce? Or is there something better
jetnjme likes this.
Old 04-30-2019 | 08:57 AM
  #47505
DesertRat's Avatar
Buggy Grip, but it may be too gummy on a track that uses corn syrup for traction aid. It works well on synthetic traction additives or crystal sugar, but it can pick up schmoo from syrup.
