Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-14-2019 | 11:33 AM
  #1936
proliteandsc's Avatar
I cut the tamiya plug off and put 4mm bullet connecters on. Not sure what battery has a Tamiya connection. I'm sure you can get an adapter on ebay or local hobby shop for almost any battery.
proliteandsc is offline
Old 04-14-2019 | 05:37 PM
  #1937
Default Ratio help needed
So me and my buddy's just got into onroad racing,real grass roots but fun.
anyway as a big tamiya kit fan I bought a tt02 hoping all the others would follow suit.one did,but the rest of the guys flaked out and got the brushed traxxas rtr car.neat as it is I'm not a rtr guy.
issue is these things are smoking fast on lipo.I thought about just buying a traxxas esc and motor to even the playing field, but I can go brushless....maybe a 15.5.....but what pinion should I run and be safe with temps?14 16?
thanks guys.
smash8ight is offline
Old 04-15-2019 | 07:42 AM
  #1938
If you buy the same motor.. your TT02 will be faster. You'll just need to match their FDR.
Nerobro is offline
Old 04-15-2019 | 12:01 PM
  #1939
The factory esc will not pull a 12 turn 550.....I don't think so anyway.
Old 04-15-2019 | 12:23 PM
  #1940
Try it! worst case, you'll need to buy a $30 brushed ESC later. :-)
Nerobro is offline
Old 04-15-2019 | 12:38 PM
  #1941
Has anyone tried a titan 550 12t on the tamiya esc?
hold on......ill try it and get back to ya....
Old 04-15-2019 | 01:21 PM
  #1942
The traxxas ratio is 9.49
I can get to that with a 19tooth pinion.....
ill run this thing hard on lipo and see what the esc says....
Old 04-15-2019 | 01:22 PM
  #1943
With that gear ratio, you should be fine.
Nerobro is offline
Old 04-15-2019 | 01:41 PM
  #1944
Raman's Avatar
With stock set up you can go to 25t pinion and that will give you 7.28 fdr.
Raman is offline
Old 04-16-2019 | 12:18 PM
  #1945
you think just the 25 tooth pinion will keep up with the 4tec.....I tried the motor and with some mods it would work.but clapping the cover down,it wasn't happy.I pulled it out.
also Robinson pinion gears seem to be off from the tamiya mesh just a hair.had to put motor in 18 tooth holes to get proper mesh(cover off)
I literally done all this in 10 mind,ill mess with it more this evening and really see what the issue is with the motor fitment.
Old 04-16-2019 | 01:43 PM
  #1946
Tamiya gears are metric 48 pitch. You need to buy a metric 48 pitch gears standard 48 pitch won't work right.
hobbyten is offline
Old 04-16-2019 | 01:55 PM
  #1947
"metric 48 pitch" is like saying metric inches. Metric gear pitch is expressed in module. The gears in the TT02, TT01, and Mini's are .6module. Smaller numbers mean smaller teeth. Module 0.6 is "close" to 48 pitch. Which sucks, becuase you ~can run them~ but it's ugly.
Robinson Racing makes .6 mod gears.
Nerobro is offline
Old 04-16-2019 | 03:17 PM
  #1948
Metric 48 and .6 are the same thing I've heard them as both.
hobbyten is offline
Old 04-16-2019 | 06:26 PM
  #1949
Hoyle33's Avatar
Gonna be painting my TT-02 Subaru Impreza body soon
How did you guys paint yours? Black on the underside? Clear windows? Black windows? Silver underlay?
I have no idea what to do
Hoyle33 is offline
Old 04-16-2019 | 07:43 PM
  #1950
Had to grind away some material off the cover to make room for the longer shaft of the 550.
19 tooth tamiya pinion....and she's hot,super smooth.
ground off most of the steering stops,and we have a race car...
those traxxas guys will not know what hit them.
