Tekno MT410
#1876
https://imgur.com/a/ss0LE
Here is my massive list of every option/part:
*TBR Front Bumper 57017 – TBR V2 Stunt Truck Rear Bumper 57030
*TBR Rear Mud Guards 57022
*Tonka Custom Painted JConcepts 0326 Body - Ford F-250 SuperCab Monster Truck
*SMC LiPo: True Spec Premium 14.8V 5200mAh 112Amps/90C Capacity
*Amass XT90-S Anti-Spark Connectors
*Pro-Line Shockwaves 3.8" MT Tires - 1193-13
*Dusty Motors Shroud (M+)
*Hobbywing EZRUN MAX 8 ESC
*Poseidon 2200kv P1515- PV22 Motor
*Castle Creations 6.5mm High Current Bullet Connector Set - CSE095-0009-00
*Futaba 3PRKA 3-Channel FHSS System
Tekno RC 1/10 MT410 Pro 4x4 Kit
Hitec Brushless Digital Ultra Torque w/PAD - HSB-9380TH
Tekno RC Pinion Gear 16T M5 - TKR4176 - Tekno RC Spur Gear 44T Hardened - TKR5115
Tekno RC Aluminum Rear Hubs – Gunmetal TKR5199A
Tekno RC CNC Split Center Diff Mounts – Aluminum TKR5262
Tekno RC Aluminum Servo Horn Double Hole 25T Spline - TKR5253B
Tekno RC Shock Caps – Aluminum TKR6003
Tekno RC Shock Cartridge Caps - Aluminum TKR6015
Tekno RC CNC Delrin Shock Cartridge Set - TKR6146
Tekno RC Shock Adjustment Nuts – Aluminum TKR6013
Tekno RC Shock Shafts w/TiNi Coating - TKR6017T / TKR6061T
Tekno RC Shock Pistons CNC 8x1.3mm - TKR6051
Tekno RC Shock Spring Set (Orange) (Front/Rear) – TKR6093 – TKR6083
Tekno RC Steering Servo Brace – Carbon fiber TKR5060C
Tekno RC Wheel Nut T Logo 17mm Serrated - TKR5116B
Tekno RC Aluminum Differential Cross Pin Set (6) - TKR5149A
Tekno RC Universal Driveshaft Sets (Front/Rear) - TKR5298
M2C Racing 7075- T6 Aircraft Grade Clear Anodized Chassis – M2C6500
M2C Racing 6061- T6 Aluminum Anodized Rear Shock Tower Brace - M2C6705
M2C Racing 6061- T6 Aluminum Anodized Short Rear Center Brace - M2C6755
M2C Racing 6061- T6 Aluminum Anodized Front/Rear Upper Shock Tower Support Braces - M2C6760 - M2C6761
M2C Racing 7075- T6 Aircraft Alum/Hard Anodized (Front/Center/Rear) HD Diff Cases - M2C6901 - M2C6900 - M2C6901
M2C Racing 6061- T6 Aluminum Solid Center Brace - M2C6905
M2C Racing Tekno Tapered 4MM Hinge Pins (4) M2C6607
M2C Racing Tekno “0” Centerline Delrin White Bushings (8) M2C6730
Mugen Seiki Diff Oil (#100000 for Front/Center) (#50000 for Rear) B0320B - B0319
Mugen Seiki Shock Oil #700 Weight (Front/Rear) B0327
ProTek RC 5x105mm Titanium Turnbuckles (2) PTK-T-7219
Team Losi Racing 8IGHT 5mm Moly Rod End Set (4) TLR344015
Losi 8.8mm Suspension Balls (4) LOSA6049
1/8 FLEXYTUB Black Shock Covers w/Mugen Seiki Emblem (4) B01
HB Racing 3x7mm Washer Set (Orange) for Servo Mount (4) HBS112794
Custom Aluminum Front Top Plate (Black) – Original part was TKR8104
Custom Aluminum Differential Top Plate (Red) – Original part was TKR8104
ProTek RC High Strength Screws (12.9 Hardened Steel)
Rear Gearbox:
*TKO Special RT 5x13x4mm Losi Inner Clutch Bearings (2) TKO-MR-695-RT
*HPI 103368 Axle Spacer 5x7x1.45mm (1)
#1877
#1879
#1880
#1882
the shorter wheel base has different characteristics. I have 3.8 badlands and backflips. Maybe I’m just like all of you and want all of the RCs lol. I just bought a buggy so if that doesn’t tickle my pickle maybe I’ll convert that to an MT because I’d most likely purchase an M2C chassis anyway.
#1885
#1887
#1888
abd the other for bashing. When the truggy scene died off for racing, they did the smart thing and catered to the bashers who never phase out like race classes.
#1889
No time soon. We're currently focused on our 1/8th nitro buggy and ebuggy right now. ET and NT based off of those will follow along with MT and probably SC, but that's a ways off. I wouldn't recommend that any of our customers wait for them.
396Likes
