Mylaps transponder missing laps >
Like Tree6Likes
Old 04-01-2019 | 10:43 AM
  #16
Originally Posted by Roelof
There is a slight possibillity that the transponder is bad. Any possibillity you can read out the hit value and compare it with others?
I'll have the race director watch it next time I'm there and have him compare the numbers to everyone else's.
dway100 is offline
Old 04-03-2019 | 10:45 AM
  #17
Originally Posted by UrabusDenis
-avoid mounting on metal or carbon,avoid mounting on servos or close to any electronics
You describe the entire car with this statement. Where do you mount it?
glennhl is offline
Old 04-03-2019 | 11:17 AM
  #18
He stated that in original post.
Andy Koback is offline
Old 04-03-2019 | 02:27 PM
  #19
Yes, he kind of described it, but didn't say exactly where he mounted it. I just don't see any spot on my car that is away from carbon, metal, or electronic components.
gigaplex likes this.
glennhl is offline
Old 04-03-2019 | 03:51 PM
  #20
Marcos.J's Avatar
Super Moderator
what esc are you using? is it a 1s?
could be the voltage is dropping below the minimum required for the PT
Marcos.J is offline
Old 04-03-2019 | 06:16 PM
  #21
Yes, it's a Hobbywing Xr10 pro 1s stock spec. The laps that it missed were just random during the race, and we were only running 5 minute races, so the battery really wasn't drained much at all. I actually had to discharge it after the race to get to storage level. I'm really wondering if the servo was somehow causing interference with the transponder signal. I have relocated it as far away from the esc, servo and receiver as possible, so I'll see if it's still missing laps next week when I get a chance to get back to the track.
dway100 is offline
Old 04-04-2019 | 01:58 AM
  #22
disaster999's Avatar
Regional Moderator
Any ESC worth a damn now a days comes with internal BEC capable of delivering 6V or higher.
also the voltage range for the transponder is 3.0 - 16 VDC. Even if he is powering the transponder directly from the 1s battery it should of still worked.
disaster999 is offline
Old 04-04-2019 | 07:44 AM
  #23
UrabusDenis's Avatar
I'll take pics when I get home of my GT, but it is mostly the same as on my nitro buggy minus the sideguard. On my JQ nitro buggy I have it as stock (on a plastic mount, mounted on its side to the servo plate), on the JQ ebuggy I have it on the plastic sideguard, and when I raced electric TC I had it up front, under the plastic front brace and inside the beginning of the foam. In none of those examples it is on or under an aluminium/carbon plate.
Sorry to hear the problem can't be solved. If it was the old one, I'd say its 99% a broken wire inside the casing. With these new ones I don't have experience, as said check the hit rate and contact Mylaps.
glennhl likes this.
UrabusDenis is offline
Old 04-04-2019 | 05:50 PM
  #24
Marcos.J's Avatar
Super Moderator
wow I didn’t know that lmfao
Marcos.J is offline
