Like Tree396Likes
Tekno MT410
Old 01-27-2019 | 09:51 AM
  #1876
vettehigh's Avatar
Thumbs up Final pics with upgraded options
https://imgur.com/a/ss0LE
Here is my massive list of every option/part:
*TBR Front Bumper 57017 – TBR V2 Stunt Truck Rear Bumper 57030
*TBR Rear Mud Guards 57022
*Tonka Custom Painted JConcepts 0326 Body - Ford F-250 SuperCab Monster Truck
*SMC LiPo: True Spec Premium 14.8V 5200mAh 112Amps/90C Capacity
*Amass XT90-S Anti-Spark Connectors
*Pro-Line Shockwaves 3.8" MT Tires - 1193-13
*Dusty Motors Shroud (M+)
*Hobbywing EZRUN MAX 8 ESC
*Poseidon 2200kv P1515- PV22 Motor
*Castle Creations 6.5mm High Current Bullet Connector Set - CSE095-0009-00
*Futaba 3PRKA 3-Channel FHSS System
Tekno RC 1/10 MT410 Pro 4x4 Kit
Hitec Brushless Digital Ultra Torque w/PAD - HSB-9380TH
Tekno RC Pinion Gear 16T M5 - TKR4176 - Tekno RC Spur Gear 44T Hardened - TKR5115
Tekno RC Aluminum Rear Hubs – Gunmetal TKR5199A
Tekno RC CNC Split Center Diff Mounts – Aluminum TKR5262
Tekno RC Aluminum Servo Horn Double Hole 25T Spline - TKR5253B
Tekno RC Shock Caps – Aluminum TKR6003
Tekno RC Shock Cartridge Caps - Aluminum TKR6015
Tekno RC CNC Delrin Shock Cartridge Set - TKR6146
Tekno RC Shock Adjustment Nuts – Aluminum TKR6013
Tekno RC Shock Shafts w/TiNi Coating - TKR6017T / TKR6061T
Tekno RC Shock Pistons CNC 8x1.3mm - TKR6051
Tekno RC Shock Spring Set (Orange) (Front/Rear) – TKR6093 – TKR6083
Tekno RC Steering Servo Brace – Carbon fiber TKR5060C
Tekno RC Wheel Nut T Logo 17mm Serrated - TKR5116B
Tekno RC Aluminum Differential Cross Pin Set (6) - TKR5149A
Tekno RC Universal Driveshaft Sets (Front/Rear) - TKR5298
M2C Racing 7075- T6 Aircraft Grade Clear Anodized Chassis – M2C6500
M2C Racing 6061- T6 Aluminum Anodized Rear Shock Tower Brace - M2C6705
M2C Racing 6061- T6 Aluminum Anodized Short Rear Center Brace - M2C6755
M2C Racing 6061- T6 Aluminum Anodized Front/Rear Upper Shock Tower Support Braces - M2C6760 - M2C6761
M2C Racing 7075- T6 Aircraft Alum/Hard Anodized (Front/Center/Rear) HD Diff Cases - M2C6901 - M2C6900 - M2C6901
M2C Racing 6061- T6 Aluminum Solid Center Brace - M2C6905
M2C Racing Tekno Tapered 4MM Hinge Pins (4) M2C6607
M2C Racing Tekno “0” Centerline Delrin White Bushings (8) M2C6730
Mugen Seiki Diff Oil (#100000 for Front/Center) (#50000 for Rear) B0320B - B0319
Mugen Seiki Shock Oil #700 Weight (Front/Rear) B0327
ProTek RC 5x105mm Titanium Turnbuckles (2) PTK-T-7219
Team Losi Racing 8IGHT 5mm Moly Rod End Set (4) TLR344015
Losi 8.8mm Suspension Balls (4) LOSA6049
1/8 FLEXYTUB Black Shock Covers w/Mugen Seiki Emblem (4) B01
HB Racing 3x7mm Washer Set (Orange) for Servo Mount (4) HBS112794
Custom Aluminum Front Top Plate (Black) – Original part was TKR8104
Custom Aluminum Differential Top Plate (Red) – Original part was TKR8104
ProTek RC High Strength Screws (12.9 Hardened Steel)
Rear Gearbox:
*TKO Special RT 5x13x4mm Losi Inner Clutch Bearings (2) TKO-MR-695-RT
*HPI 103368 Axle Spacer 5x7x1.45mm (1)
YoEddy likes this.
vettehigh is offline
Old 01-27-2019 | 10:17 AM
  #1877
Totallyosho's Avatar
Originally Posted by vettehigh
Nice URL.
stevenkelby and drewbagel423 like this.
Totallyosho is offline
Old 02-12-2019 | 07:23 PM
  #1878
Vcoupe's Avatar
Hey guys I own an ET48.3 but looking for an MT if anyone is looking to move theirs hit me up.
Vcoupe is offline
Old 02-12-2019 | 07:25 PM
  #1879
Vcoupe's Avatar
Originally Posted by Hsananikone
Teknos 1/8 scale buggys, truggies, and mt410 plus SCT all share nearly all the same parts. This is okay, tekno kits have execellent handling and durability
i know I own the ET48.3 now and love it. I hadn’t built a kit in years so it was nice to do that.
Vcoupe is offline
Old 02-13-2019 | 06:03 AM
  #1880
why not just put MT tires on your ET48.3? I never really understood why Tekno needed the MT and ET.
Micah78 is offline
Old 02-13-2019 | 04:33 PM
  #1881
aerobatics is an easy answer. Plus they have the parts bin for it
Micah78 likes this.
performula is offline
Old 02-13-2019 | 10:06 PM
  #1882
Vcoupe's Avatar
the shorter wheel base has different characteristics. I have 3.8 badlands and backflips. Maybe I’m just like all of you and want all of the RCs lol. I just bought a buggy so if that doesn’t tickle my pickle maybe I’ll convert that to an MT because I’d most likely purchase an M2C chassis anyway.
Micah78 likes this.
Vcoupe is offline
Old 02-25-2019 | 12:45 AM
  #1883
Hi everybody!
As I understand there are not any shims between small satellites and case of diff?
konstantin is offline
Old 02-25-2019 | 11:31 AM
  #1884
Matthew_Armeni's Avatar
Originally Posted by konstantin
Hi everybody!
Correct.
Matthew_Armeni is offline
Old 02-26-2019 | 01:21 AM
  #1885
gavsta72's Avatar
So metal satellite gear works with plastic diff case... is it safe?
Did anybody install some washer or shim?
maybe from HPI or from MST 0.1mm for example MXS-820012??
You don't need them it's fine. In fact they would cause the spider gears to bind
gavsta72 is offline
Old 02-26-2019 | 12:30 PM
  #1886
0verkill's Avatar
Matthew Armeni,
Will we see a MT410 V2 any time?
0verkill is offline
Old 02-28-2019 | 10:41 AM
  #1887
It is significantly cheaper by means of a bunch of lower cost components too. And as the other guy said, veryvdifferent handling.
Micah78 likes this.
Old 03-01-2019 | 11:30 PM
  #1888
Vcoupe's Avatar
or, one was originally intended for racing (ET48)
abd the other for bashing. When the truggy scene died off for racing, they did the smart thing and catered to the bashers who never phase out like race classes.
Vcoupe is offline
Old 03-02-2019 | 12:58 PM
  #1889
Originally Posted by 0verkill
Matthew Armeni,
No time soon. We're currently focused on our 1/8th nitro buggy and ebuggy right now. ET and NT based off of those will follow along with MT and probably SC, but that's a ways off. I wouldn't recommend that any of our customers wait for them.
Micah78 likes this.
Old 04-08-2019 | 10:49 AM
  #1890
RCSteveH's Avatar
Anyone out there running their MT410 on 2-3S? 550 Sized motor? Or everyone on beast mode with the 4-6S Truggy Motors?
RCSteveH is offline
