motor stutter at initial throttle ? >
Like Tree1Likes
  • 1 Post By tbrymer
Old 11-06-2018 | 06:09 PM
a1
Default motor stutter at initial throttle ?
this doesnt seem to happen all the time but I would say at least half the time. Motor stutters like a stripped gear at the beginning of slow throttle. Moving the throttle faster does not have a issue, its as normal. Any ideas?
a1 is offline
Old 11-06-2018 | 06:46 PM
tbrymer's Avatar
Sensor wire, Sensor board, motor timing to much, esc settings could be wrong. Some esc have an initial power setting.
a1 likes this.
tbrymer is online now
Old 11-06-2018 | 07:57 PM
a1
Ok thanks, thats what i figured. Looked them over real quick at track but will inspect asap. Those were my initial thoughts also but also maybe a failing motor. I guess a failing motor would not work ok half the time.
a1 is offline
Old 11-13-2018 | 08:38 AM
also wake sure one of your 3 wires aren't soldered so there is a way for one to arc to the other and are all soldered on good
Rckstar759 is offline
