What's your cutoff voltage set at? >
Old 11-02-2018 | 12:10 AM
Lineman26's Avatar
Default What's your cutoff voltage set at?
What do you guys have your cutoff voltage set at for your lipo's or lihv's? I'm curious to see what most people do..
Lineman26 is offline
Old 11-02-2018 | 05:22 AM
I run 3.5V per cell as my cut off
Djr8505 is offline
Old 11-06-2018 | 04:25 AM
rustyus's Avatar
I think the best thing to do is to be sure it's turned on. Health of LiPo cells will play a part in triggering the cutoff. Three of my ESCs that are the same brand , one seems to trigger sooner than the other two. So, that one gets set to 3.2v/cell. The other two get set at 3.4v/cell. I'm most comfortable with whatever setting gets my packs close to storage voltage after the cells have a chance to rest. YMMV.
rustyus is offline
Old 11-06-2018 | 08:14 AM
3.5 V is a reasonable setting for an ESC LVC if a little low. You have to keep in mind that the resting voltage is always higher than the loaded voltage. The ESC will respond to the loaded voltage. If you set your LVC for 3.5, you might find the voltage is higher when you stop and measure it.
Another approach is to set your LVC lower, like around 3.3V but use an alarm like this one.
https://hobbyking.com/en_us/hobbykin...B&gclsrc=aw.ds
You can set it by .1V to start beeping. You need to be running a battery with a balance connector to use this. I have my Losi SCBE setup this way. It is set to 3.6V and my LVC is at 3.3. I stop to recharge when I hear the beeping. It will be intermittent at first, kicking in during moments of high load and then then stop as the battery recovers. This gives you a "soft" warning when your battery starts to get low.
rhodesengr is offline
Old 11-13-2018 | 08:39 AM
Rckstar759 is offline
