Protek 160ss vs 160t >
Like Tree1Likes
Old 07-19-2018 | 10:09 AM
Default Protek 160ss vs 160t
what of these 2 pro tek servos should I get for my b6.1d buggy and why?
riceball777 is offline
Old 07-20-2018 | 06:56 AM
Phat-Boy's Avatar
2wd buggy 160ss will be fine if you want use it for 4wd buggy, st, and sct later on 160t.
Phat-Boy is offline
Old 07-20-2018 | 01:48 PM
Default Protek Reliabilty
Can any users of these servos (or the 150 series) comment on reliability? I thought some of the early versions had issues with shakes. I am considering Protek for my T6.1 build. The specs and price of these servos make them very attractive.
StadiumRC is offline
Old 07-20-2018 | 06:27 PM
Phat-Boy's Avatar
2 160t on my b64d and t6.1 no problem at all. I would buy savox 1258tg all most same spec if you stay 6v, also cheaper and t6.1 has lots of space no need for low profile servo same weight.
Phat-Boy is offline
Old 07-22-2018 | 12:18 AM
I just picked up the 160ss and I love it
Old 07-22-2018 | 08:37 PM
Randy_Pike's Avatar
Team Tekin
Can't go wrong with either in a 6.1
I prefer the T so my 2wd and 4wd use the same servo.
Randy_Pike is offline
Old 07-23-2018 | 12:20 AM
I plan to pick up a b64d too. Should I go with the protek 160t for the b64d ?
Old 07-23-2018 | 07:38 AM
Phat-Boy's Avatar
yes b64d has limited space better to have low profile servo.
Phat-Boy is offline
Old 07-23-2018 | 07:56 PM
RazorRC's Avatar
There's more than enough space for a full size servo in the B64D. Only reason to get a shorty is to save weight.
RazorRC is offline
Old 07-24-2018 | 12:36 AM
both the 160ss and 160t are low profile servos. But does the b64d need more servo with more torque because its 4wd? i like the 160ss because its faster.
Old 07-24-2018 | 06:44 AM
Phat-Boy's Avatar
1258tg is 52.4g and 160t is 54.5g which is heavier
Phat-Boy is offline
Old 07-24-2018 | 06:48 AM
Phat-Boy's Avatar
you need torque around 150 at least for 1/10 4wd buggy with 160ss you can use HV 7.4v if your esc has option to run HV.
Phat-Boy is offline
Old 07-24-2018 | 08:17 AM
That's a really expensive way to save maybe 10 grams.
071crazy is offline
Old 07-24-2018 | 09:11 AM
RazorRC's Avatar
Those servos are obviously not comparable — 160T has 50% more torque, does 7.4V and has an aluminum case whereas the 1258tg is weaker/6.0V/plastic case.
RazorRC is offline
Old 07-24-2018 | 09:12 AM
RazorRC's Avatar
You’d be surprised what people will spend for 10g...
slodsm likes this.
RazorRC is offline
