Axial Yeti / Axial Bomber 2-Speed Transmission with extras >
Old 05-10-2018 | 07:54 AM
scrapsz's Avatar
Default Axial Yeti / Axial Bomber 2-Speed Transmission with extras
SOLD
Hello and thank you for looking. I'm selling a gently used Axial Yeti Transmission from the kit version with installed optional Axial Hi/Lo 2-Speed setup in excellent condition. This should also work in the Axial Bomber though I believe the transfer case housing would need swapped out. This was used in my son's Yeti only a few battery packs then swapped out for single speed setup.
Please see the pictures as there is a single MIP 5mm driveshaft hub 'stuck' on the lower transfer case output shaft. The 2mm pin screw stripped out and I have not had the time (or patience) to remove it. If you have MIP spline driveshaft setup, the pin screw is very secure so this may not be an issue.
I've tossed in a few extras I had stored in the same parts bag. The Robinson X-Hard gears were installed in another Yeti transmission that I never ran and ended up parting out, they're literally new. If you can get the pin screw out of the MIP hub, they will work nicely in the transfer case.
Included in the sale...
Axial Yeti / Bomber Transmission w/Yeti Transfer Case
Axial Hi/Lo 2-Speed Transmission Components
Axial Yeti Transfer Case housing (Spare)
Robinson Racing Axial Yeti X-Hard Output Gear 27T (#1527) - Not installed
Robinson Racing Axial Yeti X-Hard Idler Gear 15T (#1515) - Not installed
SSD-RC servo mounts for 2-Speed (for Yeti)
SOLD
scrapsz is offline
Old 05-16-2018 | 07:49 AM
scrapsz's Avatar
scrapsz is offline
