YOKOMO Touring Car BD-8
#766
I use the same setup. No change at all.
#770
The BD8 is an extremely popular car and we've decide to put some attention to this model.
We've done a lot of job in the front area, as we were focused in scrub and drag reduction while turning.
For this reason, the Fenix chassis is having a special set of proprietary battery holder.
On the upper deck, extra pinion clearance is provided for those who run with high wind motors.
#775
On other hand, you might notice that we choose a countesunk hole for the grubscrew on the motor mount.
By doing so, we got 2 results.
You can to put a screw there and lock the chassis torsion in the rear end, and the screw will not touch the belt.
On other hand, you're sure that the grubscrew will not interfere with the chassis torsion
#776
125Likes
