Xray X1 - Formula One Car >
Like Tree366Likes
Old 01-25-2018 | 06:44 PM
  #2371
Nuno Gancho's Avatar
Thanks for reply
So for outdoor PIT tires you use soft in front 571 and hard in rear 572? Don’t they have pre glued set
CRC is it RT-1
Nuno Gancho is offline
Old 01-25-2018 | 06:56 PM
  #2372
Khador12's Avatar
Originally Posted by Nuno Gancho
Thanks for reply
CRC is it RT-1
Schumacher has the 571/572 pre-mounted tires on silver Tuning Haus wheels.
https://www.amainhobbies.com/schumac...xg-571/p469211
https://www.amainhobbies.com/schumac...xg-572/p469330
Khador12 is offline
Old 01-26-2018 | 11:26 AM
  #2373
Giorgio's Avatar
In Fenix, we're proud to release our OPT038 - Wide Front End kit for Xray X1
This kit creates a 3mm wider front track width that will be helpful in high grip conditions.
Car will be less aggressive and chances of traction rolling are reduced.
KE4PJO, Jack Kloeber and Adamska27 like this.
Giorgio is offline
Old 01-28-2018 | 03:09 PM
  #2374
cyclone's Avatar
Hi guys,
I have a big problem where the car feels nice everywhere except high speed corners. Especially sweepers where if i use even slightly too much steering lock, the car snap oversteers.It has a bouncing/juddering sensation as it does it.
I've tried softer and harder springs all round, thicker damping front and side, more front droop, less front droop, different camber.
Im totally lost as to how to fix this. Does anyone have any experience of fixing this problem?
This is on ETS carpet and Volante tyres, so maybe a little less grip than many of you experence where the black crc carpet is used?
Thanks for any help!
cyclone is offline
Old 01-28-2018 | 07:54 PM
  #2375
GT CRUSING's Avatar
Originally Posted by cyclone
Hi guys,
I can only think of 4 things that cause this, way too low on ride height and bottoming out, too hard rear tires (you need carpet soft rears), not enough rear downforce (So raise that rear wing height) or no carpet sauce on tires (full sauce them)
Hope that helps where to look
JimBo1008 likes this.
GT CRUSING is offline
Old 01-28-2018 | 11:59 PM
  #2376
cyclone's Avatar
thanks for your tips. I don't think its any of them though?
The height is 5mm at the rear and 4.8 at the front.
The tires are a control tire so everybody is on the same one type.
additive is controlled, and i'm applying it across the full surface of the tires both 30 minutes before the race front and rear, and 30 minutes rear but only 2 minutes front.
Thanks again
cyclone is offline
Old 01-29-2018 | 01:10 AM
  #2377
DK.Alice's Avatar
The XRAY X1 is one of the models of the Luxury car. Formula 1 racing is the head of racing technology where performance and technology-based physics challenge too much law. It has All new shock adapter for fast and easy shock piston change; New facade location and advanced power trash for improved drivability on the opposite conditions.
Update Features:
*Adjustable anti-roll bar
*Arm mount plate
*Shock spring collar
*Central mount plate
and some vital others updates.
DK.Alice is offline
Old 01-29-2018 | 01:38 AM
  #2378
sbd
Thanks again
Hi,
Too much front wing downforce. If you use montech front wing, remove all flaps. If it is the old montech version which has too much downforce even without flaps, try the new one or cut some material from the upper edges of the wing.
sbd is offline
Old 01-29-2018 | 03:57 AM
  #2379
Ph3nyx's Avatar
Hi guys,
The problem is entering the corner or exiting the corner ?
if the entry is the problem, you can flatten the angle of the central damper , (less weight transfert)
add some droop at the rear
less ride height at the rear , more at the front
it's a good start
Ph3nyx is offline
Old 01-29-2018 | 02:09 PM
  #2380
RedBMaster's Avatar
Originally Posted by SavageCanadian
My car I'm running no sway bar and no glue on the tires and it doesn't traction roll on the crc black carpet. I'm running the softest xray front spring and the black side springs
That seems a bit backwards. If you remove the sway bar shouldn't you be running a stiffer front spring?
RedBMaster is offline
Old 01-29-2018 | 04:21 PM
  #2381
Adamska27's Avatar
I have had a very similar handling issue. My advice for you is to --
1) In case you haven't, make sure chassis isn't touching at wide points (like where they narrowed it for the 2018 update) I clean and wax the bottom of the chassis with Maxima SC1 New Bike in a Can | TwistedThrottle.com
2) Replace springs - Throw out old ones and install brand new springs of same part number - these springs only have a certain number of runs in them and they get weak
3) Diff is set improperly - getting the diff setting on the factory diff takes a little practice and a good "feel" for it - the rear end sounds like it is locking up, with traction so high (even on ETS carpet) the line between tight good and too tight and bad is a very fine line
I removed all the front droop on the car somewhere in the middle of making the car handle right, so not sure how much that helped the snap loose problem, but I have all the droop shimmed out of the front kingpins, saw a few setup sheets with the same kingpin shimming and just went to that and was happy with it
Hopefully that helps
Adamska27 is offline
Old 01-29-2018 | 04:28 PM
  #2382
Adamska27's Avatar
I must have these, very nice
Old 01-29-2018 | 05:35 PM
  #2383
Dan's Avatar
Dan
No, stiffer front spring doesn't allow the car to lean (roll) into the turns as much. Traction roll will be much more violent the stiffer you go (assuming traction is high).
Tried the car without front swaybars last weekend, my car got faster. I was using Xray 1.5 front springs.
Dan is offline
Old 01-29-2018 | 10:16 PM
  #2384
Agreed. These look to be a great option for black carpet.
Vintagedriver is offline
Old 01-31-2018 | 12:50 PM
  #2385
subscribed
DG Designs is offline
