Like Tree2991Likes
1/12 forum
Old 01-06-2018 | 09:27 AM
  #46246
I need some advice on tools and equipment. I'm starting over from scratch and it might be quicker and less expensive if I know what I need and don't need. I've done a lot of research already but I'm sure I've missed a few things. Maybe if we get enough info we can put it in the Wiki for other noobs like me.
What are your "must haves" for 12th scale?
FloridaST is offline
Old 01-06-2018 | 05:15 PM
  #46247
Rugspin's Avatar
1. A 1/12th scale car.
Sorry Couldn't resist..
Rugspin is offline
Old 01-06-2018 | 08:16 PM
  #46248
JeffofSpace's Avatar
I’d say a tire truer is way up on the list.
Fastforward likes this.
JeffofSpace is offline
Old 01-06-2018 | 10:09 PM
  #46249
I'd say a pair of digital calipers and if you have the money, a setup station.
Kelseyrc is offline
Old 01-06-2018 | 10:20 PM
  #46250
fast-ho-cars's Avatar
anyone with experience of running on concrete, or what is done so foams grip it? concrete treatments, coatings, etc?
fast-ho-cars is offline
Old 01-06-2018 | 10:51 PM
  #46251
1/8 IC Fan's Avatar
we have put sugar water down in halls for demos. Let it dry, and after a while there was good tack. Then after a few rounds it would keep its tack from the heat in the tires. Not as good as Asphalt or Carpet, but it worked.
as far as coating, you can get Silica (fine powder) at Sherwin williams, you can mix it into an floor epoxy, heavy on the silica side, and it will leave a tack like fine sandpaper. they use it as an antiskid surface.
1/8 IC Fan is offline
Old 01-07-2018 | 03:42 AM
  #46252
howardcano's Avatar
Cyanoacrylate glue for front tire sidewalls.
A toenail scissor for trimming those sidewalls (and bodies).
Weldwood Contact Cement (red label, not green) for keeping tires glued to rims-- check after each run. Repair any tears with it before they turn into chunks. And if a chunk does come off, and you can find it on track, glue it back in!
The contact cement also makes good thread-locker. It keeps screws in place, but never fully hardens, so you can get the screw out if needed.
howardcano is offline
Old 01-07-2018 | 06:08 AM
  #46253
Fastforward's Avatar
1S ESC is a really nice to have, otherwise you need a voltage booster with 1S.
As previously mentioned, a tire truer would be high on the list.
Fastforward is offline
Old 01-08-2018 | 08:37 AM
  #46254
rjmakk's Avatar
Originally Posted by two shoes
We do in northern CO, 21.5 & 13.5
Which track? 5280?
rjmakk is offline
Old 01-08-2018 | 10:17 AM
  #46255
two shoes's Avatar
Originally Posted by rjmakk
Which track? 5280?
No, a little further north, in Ft. Collins: E-TEAM Hobbyplex
On road Wednesdays and Sundays.
Off road on Friday
Oval on Saturday
Drones on Tuesday
two shoes is offline
Old 01-08-2018 | 03:31 PM
  #46256
Ike's Avatar
Ike
I'm just getting back in as well... Can you (or anyone) please expand on trimming sidewalls. It seems that a lot of what has changed has to do with higher grip black carpet, and probably cars having more grip...
Thanks!
Ike is offline
Old 01-08-2018 | 03:46 PM
  #46257
howardcano's Avatar
As the front tires wear, the super-glued sidewall can form a thin lip, since it resists wear better than the normal rubber. Trimming the lip even or a little below the rest of the tire contact patch helps reduce the chance of tearing a section off when the lip starts flapping around, and reduces the possibility of the lip digging into the carpet (which makes the handling somewhat unpredictable).
You could also put the tires back on a truer, but lazy people like me don't want to take the time or effort.
Old 01-09-2018 | 08:15 AM
  #46258
IndyHobbies.com's Avatar
Pre-painted body given to me in neon pink. I ran it first time at Indy RC last weekend. Associated 12R5.2 underneath. I added more bling with prismachrome decals. You can see it coming! LOL
Antimullet likes this.
IndyHobbies.com is offline
Old 01-09-2018 | 08:39 AM
  #46259
Pinkz's Avatar
fixed broken link to AE12R6 page on WIKI
Pinkz is offline
Old 01-09-2018 | 08:40 AM
  #46260
Ike's Avatar
Ike
I used to just put them back on the truer and round off the edge a bit, but yous is a much easier solution. Thanks for the tip!
Ike is offline
