Radiolink RC3S/RC4G please hack it
Hi
Can someone please hack this device like GT3B. Here is the picture of RC3S and I think that RC4G is the same because on board they use both names. I think that the only difference is in firmware. I will solder pins and connect the TX on ST-LINK V2 when it arive.
What are you trying to achieve by hacking this?
I have two (one is the hobbyking version) and a RC3S and I cant think of on thing that this needs that it doesn't already have. Seems like it has all the bells and whistles...only thing I wouldn't mind is assigning chances 3 and 4 to different buttons...
The official firmware can be better beacause this TX can do mutch more if someone can mod this firmware.
-all channels info in one screen
-mode for crawler to select with one button front,rear, crab and 4ws steer
-more mixing options
-more channels
-for rc3s compatibility with Gyro RX
-enable/dissable sound
-Adjustable Backlight timer
-Inactivity Alarm
-ST and TH Dead Zone
-Channel Speed (All Channels)
-Dual ESC Mixing and steering
-Multi Position Switches
-Key Mapping
-Sub trims
-Adjustable long press delay
Well something like gt3s if is it possible. And there are more peope out there who want this mod.
Kind regards
-more channels
-Inactivity Alarm
-Key Mapping
-Sub trims
Kind regards
I found a new version called RC4GS. Uses the same brand chip as the FS GT3B/C but a newer version (32bit).
That one could be hackable.
Maybe even can be done over USB since it is USB upgradable.
